Hey da-anda,
For some reason my signature isn't appearing on my posts. Happens on both full post and quick post, plus the signature tick box is ticked when posting via both.
Any ideas? I've deleted and recreated the signature however no luck.
and here it is. Seems somebody played with the rights of the additional "skilled skinners" group you're member of and signatures where not allowed for it. But actually they should have still shown up, because you're ofc also a regular member that has that rights. Strange that the privileges didn't sum up.
Cheer da-anda, that's great!
Many thanks
I'm having the same issue. Box is checked when changing my signature and when making a post.
might be the same issue - will check it
ok fixed - but ruuk, boy, this is a big sig
posting just to see if my sig works, I see you have an empty sig da-anda :p
Don't need one - I'm not cool enough for one
Mine isn't showing either, probably because I'm still listed as a member of the Alaska Group, so while I'm here can I get that changed to a Skilled Skinner?
EDIT: Thank you.
