Full Version: PseudoTV Crashes Alaska?
Running Eden, installed Alaska from the 3.01 repository that is stickied. I have PseudoTV as a custom home screen icon. I can launch it fine, but whenever I exit it, it essentially locks up XBMC. Also, the icon seems to think it's now the Weather icon as the label will say some sort of Weather forecast.
Any thoughts?
i had the same problem with aeon mq3. Do you have dsplayer installed, if so that's your problem. The only way i got the problem solved was to uninstall dsplayer, and just use the stock dvdplayer.
Going through my installed add-ons list, I do not see dsplayer listed anywhere...
