script.watchlist is doing this. go to the addon forum and try to figure out the author of it - give him the xbmc.log so he can fix it. Until then you could disable that addon...
(2012-04-12, 10:25)Nemrod Wrote: [ -> ]Thanks
k, thx... i'll check with Memphiz
meanwhile, why don't you update to the latest version of watchlist ;-)
I don't know where to find it, didn't see an addon with this name in the menu.
Thanks but i'm not sure to understand.
What exactly is Watchlist ? An addon, a script ? Maybe it's the same but i'm a bit noob on XBMC.
What do i have to do with the liste you've just provided ? Rempalce it manually ?
Nemrod
(2012-04-25, 22:11)Nemrod Wrote: [ -> ]I don't know where to find it, didn't see an addon with this name in the menu.
as your logfile is a few weeks old, chances are you're currently already using the latest version.
if you've enabled 'auto update' for addons, you should be safe.
watchlist is indeed a script used be several skins.
http://forum.xbmc.org/showthread.php?tid=113702
Yes, i forgot to mention it, auto update is enabled.
My skins are Aeon Nox, Aen MQ 3, Confluence & Glass.
Nemrod
I've made a fresh install, i'm gonna test and post the result.
Nemrod
Edit:
Something i forgot to mention, sometime XBMC seems to freeze when i want a quit :
http://pastebin.com/raw.php?i=fT0LCp16
This crash is not on exiting XBMC but on startup. Do you have dualscreen setup? It might be that this crash is already fixed in the latest nightly builds...
(2012-07-09, 16:27)Memphiz Wrote: [ -> ]This crash is not on exiting XBMC but on startup. Do you have dualscreen setup? It might be that this crash is already fixed in the latest nightly builds...
Thanks for your answer
No, i only have one screen plugged on my Mac Mini. Sometime i used OS X screen sharing from my MBP for file management.
Nemrod
