2012-04-12, 23:41
Hi All,
I have a multi room setup of XBMC spread across two macs running Lion and two AppleTV (1st Gen) running Crystalbuntu. All of these machines are running XBMC Eden.
One of the macs is setup as the server with fixed IP address (also called Jack) and all of my content attached on external USB drives. These drives are all shared by afp. MySQL runs on this mac. All of the other machines are correctly configured to look for this MySQL database and they all pick up the library and everything works great...for a while.
On a number of occasions I have turned on one of the AppleTV devices and attempted to play a video from the library only to see a message pop up saying something like "File is no longer available, would you like to remove it from the library". I say no of course. If I go to the Videos>Files menu and attempt to browse to the share I can load up the zeroconf menu and see my server (Jack (AFP)) but when I select it no afp shares are available. Nor can I enter the share address manually. If I restart the AppleTV then 9 times out of 10 I can play videos from my library and browsing to the zerconf>Jack (AFP) folder I can see all of my AFP shares without any problem.
This leads me to believe that something within XBMC or the underlying OS is locking up the afp protocol which can only be rectified by a reboot.
Does anybody have any thoughts on this?
Andy
Andy
