So I had the 4 series oh 'Heroes', verified and renamed with sickbeard.
I have the folders there in as follows: video/series/heroes/ Then each with there own season folder and espidoses including nfo,jpg etc are in them
They were on XBMC and they were all displaying and playing correctly.
Then i turned on xbmc again it was only picking up 4 shows in series one. I have checked the folder and the videos are in there.
The videos play fine in vlc and wmp. For some reason its not scraping them.
I deleted the shows from xbmc. Restarted my NAS and XBMC and after rescanning. The same thing happened. The first season only had 4 episodes.
Any suggestions?
The
Debug Log, as always, will tell you the answer. Refresh the show (and all episodes) and grab the resulting
Debug Log.
(2012-04-14, 02:13)jmarshall Wrote: [ -> ]The debug log, as always, will tell you the answer. Refresh the show (and all episodes) and grab the resulting debug log.
After refreshing, restarting, removing and adding again I still cant get episodes to appear. In season 1 of heroes this is all that show up. Even though I have all episodes.
S01 E1,2,3,17,22,23
I think ive done what you said.
Hopefully someone can translate this log into some useful information
http://xbmclogs.com/show.php?id=1747
Thanks in advance and if there is anything else i should do please let me know
Just a quick note.
I also have xbmc setup on my Kubuntu machine and it finds, displays and plays all the videos.
I also noticed it has happened to a few other series on my windows machine, but none in linux are effected
Same things has happened wit game of thrones. I even converted mp3 to mp4. It found it first but not the sdame thing has happened
Any ideas?
