I#m using eden and although I can list games, when I click on a hockey stream it just says script failed.
Any ideas why this could be?
Edit: I have an account now and logged in through xbmc. Howver, whenever I select a game, it just lists a blank screen with the 2 folder dots ..
I click login, it says succeeded. I then click IP exception and it says failed.
Any ideas on what the problem might be with this plugin or if there is a better ice hockey plugin available?
Yea if anyone has any good recommendations for a good hockey stream that would be amazing.
I don't have an add-on, but I use myp2p.pe, and I've watched two of the NHL playoffs so far. It would be nice if there were a script for that site, though.
the sportsdevil plugin should be enough for all the games
#EXTM3U
#EXTINF:0,1. NBC
rtmp://176.31.231.57/edge/ag9efgb4nrjpipd swfUrl=http://www.ilive.to/jwplayer/player.swf pageUrl=http://www.ilive.to/3809/NBC tcUrl=rtmp://176.31.231.57/edge timeout=10
#EXTINF:0,2. NBCSN
rtmp://176.31.231.57/edge/lxec9dls3w9rjop swfUrl=http://static.ilive.to/jwplayer/player.swf pageUrl=http://www.ilive.to/18843/VH_1 tcUrl=rtmp://176.31.231.57/edge timeout=10
#EXTINF:0,3. CNBC
rtsp://live.yycast.com:1935/live/_definst_/cnbc0100
since most of the games are being broadcast on nbc,nbcsn & cnbc just save the above code in a textfile and name it "whatever you want".m3u
put it in your xbmc/userdata/playlists/video folder and play via videos-submenu
all that's left is to check tvguide.com for game times
(2012-04-16, 21:50)thatguy7669 Wrote: [ -> ]the sportsdevil plugin should be enough for all the games
#EXTM3U
#EXTINF:0,1. NBC
#EXTINF:0,2. NBCSN
#EXTINF:0,3. CNBC
what about if you#re not in the US, won#t it be blocked on IP address?
also nbc doesn#t show past games?!
no all you can watch are live games since those are links to regular tv streams.
they work from anywhere and are not geoblocked (i'm in germany myself)
for recaps, i'd use nhl.com or livetv.ru
other than that, i really can recommend the sportsdevil plugin
What about CBC? I have LiveTV running and it never comes in. I run Canada in Demand and I cant get it working either.......would rather listen to commentators who actually know something about the game, you know.
Any replay channels not blocked on IP?
Anyone tried the hockey streams plugin?
I got fed up of the current hockey streams plugin breaking and have rolled my own, it only supports archived streams on xbmc so far but when the next available live game rolls round I'll add live game functionality.
If you want to take a look at the plugin visit
http://code.google.com/p/xbmc-hockey-streams/
Can I use it on livestreams plugin through xml file?
#EXTM3U
#EXTINF:0,1. NBC
#EXTINF:0,2. NBCSN
#EXTINF:0,3. CNBC
