So the shutdown error is making this absolutely unusable, merely disabling watchdog from the addon menu causes an instant crash - watchdog is clearly the culprit. I've even reproduced this on a fresh install, with no other addons installed on two different computers, with two physical folders and two networked. Additionally, it seems watchdog isn't even working (nothing is added to library, ever), and when it is installed none of my other addons are working. It seems like that watchdog is breaking on a network scan & locking out other addons from working as well as the program from ever shutting down correctly. Totally breaks shutdown timer/normal windows shutdown.
two examples:
22:20:49 T:212 NOTICE: Thread Background Loader start, auto delete: false
22:21:35 T:56 NOTICE: Previous line repeats 9 times.
22:21:35 T:56 ERROR: XBPyThread:
top - script C:\Users\Logan\AppData\Roaming\XBMC\addons\service.watchdog\service.py didn't stop in 5 seconds - let's kill it
22:21:36 T:3608 NOTICE: Thread Background Loader start, auto delete: false
and
22:33:34 T:7236 NOTICE: Saving settings
22:33:34 T:7236 NOTICE: stop all
22:33:34 T:7236 NOTICE: ES: Stopping event server
22:33:34 T:7236 NOTICE: stopping zeroconf publishing
22:33:34 T:7236 NOTICE: Webserver: Stopping...
22:33:34 T:7236 NOTICE: WebServer: Stopped the webserver
22:33:34 T:7236 NOTICE: Webserver: Stopped...
22:33:35 T:9088 NOTICE: ES: UDP Event server stopped
22:33:35 T:7236 NOTICE: stop sap announcement listener
22:33:35 T:7236 NOTICE: clean cached files!
22:33:35 T:7236 NOTICE: unload skin
22:33:38 T:10088 NOTICE: [trakt] Beginning shut down.
22:33:38 T:10088 NOTICE: [trakt] 'script.trakt' shutting down.
22:33:40 T:5312 NOTICE: StorageServer-2.5.2 Closed down
22:33:46 T:7236 ERROR: XBPyThread:
22:33:47 T:7236 NOTICE: stop python
each time is followed by about ten seconds of hang time, then a windows error message. If you want, I will give every single detail of my settings that you need to reproduce and fix this critical bug.
