option "smoothed playback" doesn´t work in cvs. to avoid jerky playback , i have to set autosync=30 in mplayer.conf. if i´am right
this what "smoothed playback" should do.
same for me ...works better if i edit the mplayer.conf.
i´m not sure what happens if i have disabled in gui and enabled in file..
what will it use then?
hmm.. had no real way to test it.. but technically it should work
however it might get overridden by a setting autosync 0 in mplayer.conf.. make sure it's really commented out.
<edit> just checked, it's not working as expected. will fix </edit>
