Full Version: TV Show Library not updating
xbmc eden and aeon nox 2.0
When I first set up my sources all my tv shows were added fine and art downloaded fine, but the shows aren't updating. Episodes I watched from other computers and deleted are still showing up in the xbmc tv shows (they don't play of course) and new shows I've added don't show up.
My folder structure is:
Server/Pandstv/Fringe/Episode1.avi
This seems like it should be so simple, what am I screwing up? The sources are set to autoscan. I've tried doing a manual "scan for new content". I keep googling, but the result that keeps coming up the most is something about an autoupdate not being compatible with eden.
Thanks in advance.
The Debug Log is always the first step. Enable debug logging, pick a show that isn't up to date, TV Show Info -> Refresh.
Check the Debug Log.
That naming doesn't sound right either - usually the season number as well as the episode number is required.
But the debug log will tell all
I checked the wiki, it didn't look like seasons were required, but I'll try adding it just to verify.
Here is the section of my log file that mentions the show I tested, Make it or Break it (My wife's show I swear). I verified that the server is up and running. I noticed a lot of errors in the section before the debug was even turned on. Maybe I just need to do an uninstall and reinstall.
16:10:13 T:3752 DEBUG: CTextureCache::GetImageHash - unable to stat url smb://SMITHSERVER/Videos/Pam Scott TV/Make it or Break it/Make it or Break it/fanart.jpg
16:10:14 T:2244 DEBUG: SDLKeyboard: scancode: 4b, sym: 0114, unicode: 0000, modifier: 0
16:10:14 T:2244 DEBUG: CApplication::OnKey: left (f082) pressed, action is Left
16:10:16 T:2244 DEBUG: SDLKeyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
16:10:16 T:2244 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
16:10:16 T:2244 DEBUG: CApplication::ExecuteXBMCAction : Translating SendClick(2003,6)
16:10:16 T:2244 DEBUG: CApplication::ExecuteXBMCAction : To SendClick(2003,6)
16:10:16 T:2244 INFO: Loading skin file: DialogYesNo.xml
16:10:16 T:2244 DEBUG: ------ Window Init (DialogYesNo.xml) ------
16:10:19 T:2244 DEBUG: SDLKeyboard: scancode: 4d, sym: 0113, unicode: 0000, modifier: 0
16:10:19 T:2244 DEBUG: CApplication::OnKey: right (f083) pressed, action is Right
16:10:25 T:2244 DEBUG: SDLKeyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
16:10:25 T:2244 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
16:10:25 T:2244 DEBUG: ------ Window Deinit (DialogYesNo.xml) ------
16:10:25 T:2244 DEBUG: ------ Window Deinit (DialogVideoInfo.xml) ------
16:10:25 T:2244 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'smb://SMITHSERVER/Videos/Pam Scott TV/Make it or Break it/'
16:10:25 T:2244 INFO: Loading skin file: DialogProgress.xml
16:10:25 T:2244 DEBUG: DialogProgress::StartModal called
16:10:25 T:2244 DEBUG: ------ Window Init (DialogProgress.xml) ------
16:10:26 T:3056 DEBUG: Thread CVideoInfoDownloader start, auto delete: 0
16:10:26 T:3056 DEBUG: ADDON::CScraper::FindMovie: Searching for 'Make it or Break it' using The TVDB scraper (path: 'C:\Program Files (x86)\XBMC\addons\metadata.tvdb.com', content: 'tvshows', version: '1.2.4')
16:10:26 T:3056 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=make%20it%20or%20break%20it&amp;language=en</url>
16:10:26 T:3056 DEBUG: FileCurl::Open(001ADC40) http://www.thetvdb.com/api/GetSeries.php...anguage=en
16:10:26 T:3056 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://www.thetvdb.com
16:10:35 T:2244 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http://www.google.com (easy=1399EC48, multi=00000000)
16:10:42 T:2244 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
16:10:43 T:4892 DEBUG: Thread Jobworker 4892 terminating (autodelete)
16:10:43 T:3752 DEBUG: Thread Jobworker 3752 terminating (autodelete)
16:11:06 T:3056 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 28
16:11:06 T:3056 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
16:11:06 T:3056 ERROR: ADDON::CScraper::Run: Unable to parse web site
16:11:06 T:3056 ERROR: CVideoInfoDownloader:Tonguerocess: Error looking up item Make it or Break it
16:11:06 T:3056 DEBUG: Thread CVideoInfoDownloader 3056 terminating
16:11:06 T:2244 INFO: Loading skin file: DialogOK.xml
TheTVDb.com is currently having issues. Give in 24 hours or so.
That shouldn't cause problems with my local media not showing up or refreshing though, should it?
(2012-04-16, 03:21)hi_its_me_scott Wrote: [ -> ]That shouldn't cause problems with my local media not showing up or refreshing though, should it?
That site is where the meta-data (summaries, cover art, thumbnails, etc) are taken from, so if it can't connect to the site then it won't add an entry in the local library for the local media.
I see, thanks for all the help guys.
I'm getting there, slowly but surely. My biggest problem with figuring out my own solutions is not knowing the terminology. It's hard to find what you're looking for if you're searching the wrong key words.
I've been toying around with the idea for a glossary of terms to be put on the XBMC Wiki. I bet it would help a lot of people.
