2012-04-19, 17:42
I'll help with this too, I am just installing a new machine with the pvr branch, mythtv and ubuntu 12.04. I assume I use the same apt -get requirements as tsp42's?
Cheers
Bruce
Cheers
Bruce
(2012-04-19, 17:27)rdoac Wrote: [ -> ]Ok, but it says it's unplayable and returns to the menu..hmm ok. It should recognize version 72. Sounds like it is not properly installed.
13:09:21 T:2950683504 DEBUG: CFileCache::Open - opening <dev-addons/andre/addons.xml.md5> using cache
13:09:21 T:2950683504 DEBUG: FileCurl::Open(0x99d1960) http://xbmcaddons.com/dev-addons/andre/addons.xml.md5
13:09:21 T:2950683504 INFO: easy_aquire - Created session to http://xbmcaddons.com
13:09:22 T:2959076208 DEBUG: Thread XFILE::CFileCache start, auto delete: 0
13:09:22 T:2959076208 INFO: CFileCache::Process - Hit eof.
13:09:22 T:2959076208 DEBUG: Thread XFILE::CFileCache 2959076208 terminating
13:09:22 T:2950683504 DEBUG: CFileCache::Open - opening <dev-addons/andre/addons.xml> using cache
13:09:22 T:2950683504 DEBUG: FileCurl::Open(0x99c92f8) http://xbmcaddons.com/dev-addons/andre/addons.xml
13:09:22 T:2950683504 ERROR: Repository andrepl's Addons returned no add-ons, listing may have failed
13:09:22 T:3018336064 DEBUG: XLCDproc::Connect - LCDproc data: Columns 20 - Rows 2.
13:09:22 T:2959076208 DEBUG: Received request to serve unknown md5 'DeviceDescription.xml'
13:33:33 T:2986093424 DEBUG: DoWork - took 148 ms to load special://skin/backgrounds/videos.jpg
13:33:33 T:2973088624 DEBUG: DoWork - took 144 ms to load special://skin/backgrounds/videos.jpg
13:33:33 T:3017094976 DEBUG: UPower: Recieved an unknown signal NameAcquired
13:33:33 T:3017094976 DEBUG: Checking repositories for updates (triggered by XBMC.org Add-ons)
13:33:33 T:2986093424 DEBUG: CFileCache::Open - opening <addons/eden-pre/addons.xml.md5> using cache
13:33:33 T:2986093424 DEBUG: FileCurl::Open(0xb16a43e0) http://mirrors.xbmc.org/addons/eden-pre/addons.xml.md5
13:33:33 T:2986093424 INFO: easy_aquire - Created session to http://mirrors.xbmc.org
13:33:37 T:3017094976 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:33:37 T:2977700720 WARNING: FillBuffer: curl failed with code 28
13:33:37 T:2977700720 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
13:33:37 T:2977700720 DEBUG: FileCurl::Open(0xb17c10f8) http://feeds.feedburner.com/xbmc
13:33:38 T:2964695920 INFO: WEATHER: Weather download successful
13:33:38 T:2964695920 DEBUG: GetZipList - Processing zip://special%3a%2f%2fxbmc%2fmedia%2fweather%2ezip/
13:33:38 T:2977700720 DEBUG: Got rss feed: http://feeds.feedburner.com/xbmc
13:33:38 T:2977700720 DEBUG: RSS feed encoding: UTF-8
13:33:38 T:2977700720 DEBUG: Parsed rss feed: http://feeds.feedburner.com/xbmc
13:33:38 T:2977700720 DEBUG: Thread CRssReader 2977700720 terminating
13:33:38 T:2964695920 ERROR: WEATHER: Unable to get data: Invalid License Key.
13:33:38 T:2884946800 DEBUG: Thread XFILE::CFileCache start, auto delete: 0
13:33:38 T:2884946800 INFO: CFileCache::Process - Hit eof.
13:33:38 T:2884946800 DEBUG: Thread XFILE::CFileCache 2884946800 terminating
13:33:38 T:2986093424 DEBUG: CFileCache::Open - opening <addons/eden-pre/addons.xml> using cache
13:33:38 T:2986093424 DEBUG: FileCurl::Open(0xb16a43d0) http://mirrors.xbmc.org/addons/eden-pre/addons.xml
13:33:39 T:2884946800 INFO: CFileCache::Process - Hit eof.
13:33:39 T:2884946800 DEBUG: Thread XFILE::CFileCache 2884946800 terminating
13:33:39 T:2986093424 ERROR: ADDON: extension '' is not currently supported for service addon
(2012-04-19, 14:15)rdoac Wrote: [ -> ]Hmmm still getting protocol issues??
07:12:05 T:2929036144 ERROR: (cmyth)cmyth_conn_connect: asked for version 8, got version 72
07:12:05 T:2929036144 ERROR: (cmyth)cmyth_conn_connect: failed to connect with any version
How do I check which version I'm running, did a git clone but maybe it's set to the wrong branch?
$ git checkout myth-0.25
$ ./bootstrap
$ ./configure
$ make clean
$ make
$ ./xbmc.bin
(2012-04-19, 17:42)OzSpeedway Wrote: [ -> ]I'll help with this too, I am just installing a new machine with the pvr branch, mythtv and ubuntu 12.04. I assume I use the same apt -get requirements as tsp42's?
Cheers
Bruce
(2012-04-19, 22:04)dteirney Wrote: [ -> ](2012-04-19, 17:42)OzSpeedway Wrote: [ -> ]I'll help with this too, I am just installing a new machine with the pvr branch, mythtv and ubuntu 12.04. I assume I use the same apt -get requirements as tsp42's?
Cheers
Bruce
The libraries that need to be on the machine are those needed for building standard vanilla XBMC. If you have the dependencies for tsp's PVR branch that will probably be fine.
(2012-04-19, 21:30)dteirney Wrote: [ -> ]After doing a git clone you have to change to the myth-0.25 branch.
Code:$ git checkout myth-0.25
Due to all the other problems you seem to be having I'd recommend re-building and then re-install or run XBMC from the source directory.
Code:$ ./bootstrap
$ ./configure
$ make clean
$ make
$ ./xbmc.bin
21:46:44 T:2980875120 DEBUG: Process - MythTV event UPDATE_FILE_SIZE: 10391 2012-04-19T21:00:00 1558047180
21:46:48 T:2881485680 DEBUG: CDVDPlayerAudio:: Discontinuity - was:837397627.622445, should be:837409482.573436, error:11854.950991
21:46:54 T:2881485680 DEBUG: CDVDPlayerAudio:: Discontinuity - was:843538124.702436, should be:843549492.173726, error:11367.471291
21:46:55 T:2980875120 DEBUG: Process - MythTV event UPDATE_FILE_SIZE: 10391 2012-04-19T21:00:00 1564001704
21:47:00 T:2881485680 DEBUG: CDVDPlayerAudio:: Discontinuity - was:849682075.657726, should be:849693413.001249, error:11337.343523
21:47:05 T:2980875120 DEBUG: Process - MythTV event UPDATE_FILE_SIZE: 10391 2012-04-19T21:00:00 1569332256
21:47:06 T:2881485680 DEBUG: CDVDPlayerAudio:: Discontinuity - was:855821827.580249, should be:855833227.598073, error:11400.017823
