Full Version: Problem with scraper
I'm running XBMC Eden on Ubuntu and seem to have some issues with the scraper not working.
Neither the TVDB or the TMDB is running..
I got 2 disks connected by USB and they show up under files but when I right click and chose the scraper and enter the settings nothing happens more than that it asks if I want to refresh the data for that path after which nothing happens.
If I try to add it as a new source from the root folder it just show up twice instead.
Any ideas?
I've now tried to use the imdb scraper instead but I have the same issue.
It just says that this will refresh the date for this path and then nothing happens at all.
Any ideas?
Any ideas at all?
I have internet access, i can find the folders (2 on USB2 WD external drives) and i can enter the settings on the scraper, but nothing happens afterwards.
Do i need to re-install everything?
See the wiki on howto add a source.
And if you are not sure, you can always try to reinstall XBMCbuntu to be sure.
that's the thing, i get to step 8 but then nothing happens except that the folder shows up twice in the list.
for some reason it looks like the scraper doesn't even start since i dont get any more messages after clicking "yes" at step 8.
Reinstall xbmcbuntu and plugin the hd's again and try to do it exactly as explained in the wiki.
