2012-04-17, 02:15
2012-04-17, 02:15
Now I want to change to http://www.newegg.com/Product/Product.as...6820148559
on my rig.... lol maybe
Onizuka why the [HEATSINK] Scythe Shuriken Rev.B SCSK-1100 - Processor cooler - 100 mm ?
Well i have that on my other rig and its awesome.....
I have the Scythe Shuriken Rev.B SCSK-1100 also .... its easier to install..... just clip on the sides....
2012-04-17, 02:21
Scythe BIG Shuriken 2 is really easy to install too!
2012-04-17, 02:26
(2012-04-17, 02:21)eskro Wrote: [ -> ]Scythe BIG Shuriken 2 is really easy to install too!
It's a little harder..... take your time....
Pea size of the thermal paste on it on the center..... not too much or it will ooze out....
let me know if you need some pointers on any cpu cooler u buy...
2012-04-17, 02:27
Pea size or blood drop ?
2012-04-17, 02:32
lol Pea size........ oh and yes my Hyper X ram has been stable....
http://www.youtube.com/watch?v=EyXLu1Ms-q4 pea size is the best..... always done it that way..... one time I added a little too much and it went out all sides.... i was scared... lol.... cleaned it up....
2012-04-17, 03:31
For the Scythe Shuriken:
I didn't even know the difference, novice here! Is one better than the other?
And you want to move from Kingston to Crucial now?!? Really that much better?
2012-04-17, 04:39
Witch ever ram you choose is fine.... kingstone is great... I have that one and its been stable after 8 hours of memtes86+ ...now for your Shuriken either is fine....
I believe both will fit the ML03B but I can not confirm.....
This one is the easy one to put on..... Very quiet at low RPM - High RPM LOUD
I have this Scythe SCSK-1100 100mm Shuriken Rev. B 3 Heat Pipes CPU Cooler
This one is easy too but just take your time..... Very quiet at low RPM - High RPM A Little less louder....
and this Scythe SCBSK-2100 120mm Sleeve BIG Shuriken 2 Rev. B
Enjoy!
Enjoy!
2012-04-17, 05:01
+1 for Scythe SCBSK-2100
2012-04-17, 06:43
2012-04-17, 16:15
Updated to Scythe SCBSK-2100, thanks!
Question: Is a case fan really required, or simply by preference?
2012-04-17, 17:15
(2012-04-17, 16:15)onizuka Wrote: [ -> ]Updated to Scythe SCBSK-2100, thanks!
It all depends on your temps.... use CPUID hardware monitor or something...... if you use one of your case fans and its not loud and ok with you then leave it on.....
2012-04-17, 17:24
the ML03B supports 4x80mm fans but u can start off without buying them...
i dont think you'll really need them.
your not using a FanLess GPU in there too so...
i woulnd't worry.
i woulnd't worry.
2012-04-17, 20:49
2012-04-17, 21:49
(2012-04-17, 20:49)onizuka Wrote: [ -> ]Will this little fella fit in the case?Why? Are you a hardcore Gamer?
http://www.amazon.com/HIS-Express-Profil...B0062HIQLU
HD6550D in it should allow you to playback some games....
