2016-01-30, 01:03
2016-01-30, 07:00
Thanks I'll give that ago. For me nothing is working since been using jarvis. Worked with Isengard using original code with just updated windows. I see your code is different at the start so I will give that ago. Thank you very much.
2016-01-31, 01:11
Yep that works. Thanks. I found the issue, seems jarvis need a visible tag now. Once I added to my custom overlay it works. So thank you very much helps a lot.
PHP Code:
<visible>!Window.IsVisible (startup)</visible>
2016-01-31, 11:34
But it's always had that visible condition for Frodo and Gotham.
2016-02-03, 00:19
Ah found out when it stopped working in jarvis. In jarvis alpha 3 is doesn't work. So I stopped developing for jarvis but now it works so all is good. Thanks again. At least I know it was not just me.
2016-02-03, 01:35
At one time it was using window id="50" which Jarvis is now using for the Event Log window.
scott s.
scott s.
2016-02-04, 00:54
Ah yes you are right. Thanks Scott
2016-02-05, 11:02
Guy... sorry to interupt, but I dont know what I am missing here since this does not work for me... the F6 and F7 doesnt do anything. Can anyone point me out where is my error?
I am on Jarvis RC3
What have I done:
1. Downloaded gotham version form first post
2. Downloaded Hitcher's updated Custom_Overlay.xml posted on http://pastebin.com/jtA0Nd9B
3. Placed Hitcher's updated Custom_Overlay.xml to 1080i folder under the skin I am using (Arctic Zepyr mod from Braz)
4. Placed debuggrid1080.png to skin root folder
5. Placed keymap.xml in %appdata%\kodi\userdata\keymaps folder
Starting kodi... trying F6,F7... nada
I am on Jarvis RC3
What have I done:
2016-02-05, 11:51
(2016-02-05, 11:02)Crssi Wrote: [ -> ]Guy... sorry to interupt, but I dont know what I am missing here since this does not work for me... the F6 and F7 doesnt do anything. Can anyone point me out where is my error?
I am on Jarvis RC3
What have I done:
The .png is not in the root folder, is in media/extras/debuggrid1080.png
PHP Code:
<texture>special://skin/extras/debuggrid1080.png</texture>
2016-02-05, 14:13
Thats it. At least for F6, now the grid is working.
Thank you.
Maybe first post should be updated.
There I still have a problem with F7, it doesnt do anything.
<F7>Skin.ToggleSetting(HideDebugInfo)</F7>
I have put this additional line now to keymap:
<F8>Skin.ToggleDebug</F8>
F8 is working. I suppose that the function/effect is the same?
I am asking because I have just the info the left side (missing right) like: Window: home (Home.xml) Mouse: (32,343) Focused: 302 (list)
Regards
Thank you.
Regards
2016-04-25, 10:45
I cannot get it to work. F6/7 does notthing. I tried adding F8 (skin.togglesdebug), and that works. Tried three different skins, changed F6/7 to 9/10, just to see if the keys were mapped to something else, but nothing. And I replaced the xml file with the code in http://pastebin.com/jtA0Nd9B
I'm running the latest stable Jarvis version.
Edit: Nevermind. I had put the pngs in media/extras, not /extras. It works!
