New Release.
Media Companion 3.606b
There are a few new features in this build. One that requires specific mentioning.
<uniqueid>
This new field is stored in each episode's nfo file. It is the episode's Unique ID from TVDB.
But! Users will have to use Tv Show's Batch Rescrape Wizard, to update existing episode nfo's with this entry.
To do this, it is suggested to run the
Batch Rescrape Wizard, and select the episode's
Rating to be rescraped for every episode in every Tv Show.
This will add the
<uniqueid> field into the episode nfo's, updating this data for use with
Trakt (when scraped into XBMC), and in the future of MC, will be used for Missing Episode code.
Watched indicator in Tv Tree list
Also added is a Watched indicator to the TV Tree. A Green Tick will be shown against each episode that has been set to Watched.
If all episodes in a Season are set to watched, the Season heading also have a Green Tick.
Finally, if all Seasons are set to Watched, then the Show's heading will have a Green Tick.
There is one glitch in this code, yet to be resolved, but it is minor. Multi-episodes when set to watched, will show duplicate entries of the last episode in the multi-episode file. A Refresh-All fixed this minor glitch, and work will be done to get it functioning correctly.
New Renaming folder option
A new option has been added to the Renaming group of options.
Create Folder under Root folder, if not in a Movie Set
This is for user's who have renamed a movie's folder, and found they have one movie in a Set, but do not wish to have this movie in a Movie Set folder. Once a user selects this option, and then renames the Movie's folder, the folder will be removed from the Movie Set folder, and placed in the Root Folder. Movie Set folder will be deleted if empty. Note: User must change the Movie's Set to
-none- for this to work correctly.
Missing Episodes
A lot of work has been done on the Missing episode code, to hopefully speed up, add last refreshed info, as well as correctly display missing episodes.
If
Display Missing Episodes is NOT selected, then the options
Missing Episodes and
Missing Aired are not available to the user. This ensured user's don't select these options when missing data is not present.
Oh, and there have been plenty of bug fixes.
Feedback would be appreciated.
Download Link for MC 3.606b
Revision History
