(2015-03-10, 00:54)Levi59 Wrote: [ -> ]one of the show was back but there was some error with multipart episodes (some doesn't appear, other are in double : S01E02... , S01E02... , S01E04, S01E04...) and with some episode (one special episode of space symphony maetel don't appear in the list but an nfo was created with only mediainfo tags)
I have wanted to force the language so i have edited tvdb.xml and replaced "$INFO[language]" by "fr". I have choose "rescrap this episode and get this error :
As you can see, it use an "en" url...
I will test with a clean install. I must only remove media compagnon directory or there is another data folder?
Noticed in the image you attached, that the error was caused by a missing TVDB ID. See between words series and default, are two
//. The TVDB ID should be in-between these. This is the cause of you receiving that error. Probably from modifying the tvdb.xml file with an improper editor (a lot of text editor's do not save xml files without addition of illegal characters).
(2015-03-10, 14:44)Levi59 Wrote: [ -> ] (2015-03-10, 10:10)vbat99 Wrote: [ -> ] (2015-03-10, 09:43)Levi59 Wrote: [ -> ]same thing with clean install, no scrap for some episodes or scrap in English.
Really sorry, but it's been impossible to get time on my computer to sort this out.
But please know, I will get onto this in the next day or two.
no problem
So, I have been tramping through the code for scraping and rescraping Tv Show's, and found one big oops, and one minor oops.
Big Oops is that scraping a new Tv Show is only done through Media Companion's TVDB scraper. XBMC TVDB scraper is ignored. Why?? No Idea. Will be looking at adding it back.
Funny thing is, if you r-click the show and select
Rescrape TvShow then the routine will use MC or XBMC TVDB scraper. Huh! Someone did a half-arse job here.
Minor Oops, is the XBMC TVDB scraper language is ignored. Now this one I have put a fix in place, so it'll be sorted for the next release for sure.
My findings. Can't get it to fault. And here's what I did. Selected the show Elementary for my testing. Initial scrape in English. All episodes scraped in english. (nine episodes in Season 1 and in season 2, 18 Episodes total)
Deleted all nfo's, removed Elementary from Folder list.
Changed MC's scraper to Francais, and added Elementary. Show scraped in French. Scraped all episode. All episodes in French.
My test with XBMC TVDB scraper was pointless as the scraper was not in the code anymore, but I did fix the language. - Remember, XBMC TVDB code is not in the Initial scrape Tv Show currently, but it is still used in Episode scraper, Tv Show Rescraper, Batch Rescraper.
So. As the XBMC TVDB scraper language was ignored. This may have contributed to your plot changing from French to english, but in my quick testing, I can't get that to validate.
You will need to check the Tv Show's nfo for the following entry
<language>fr</language>
fr for French. If this is english, I recommend the following.
In Media Companion, select the Tv Show.
Go to
Tv Show Selector tab, and select the Tv Show again.
But, in the right side of this tab, Select
Francais as your language for this show, then click the
Scrape Show with Selected Options button
