(2016-01-25, 10:16)McButton Wrote: [ -> ]Is there a way to just have TV SHOW invalid .nfos get overwitten instead of changed to .info? I see it for movies but TV just keeps on rolling. I just don't want a bunch of nfo AND info in each folder. It's messing with my biz.
In General Preferences,
Rename non-compliant scene 'nfo' to 'info'. UnSelect this and MC should delete the nfo instead of renaming it.
Quote:Also, is there a way to change where in the video MC pulls screenshots for missing artwork? I only saw 1 option.
..just curious...nothing huge.
TV Preferences,....Huh? Box to select delay in seconds is missing....OGM! Will fix this in the next release.
Quote:Also, also, also....is there a way to have MC ignore scanning the whole Movie database and scan only newly added items? Not sure if that technology is a thing, but it seems like it would save time. I only add like 1 or 2 movies a month.
Unfortunately no. While MC knows you have certain Movies, it needs to check and find any new movies, where-ever they may be.
But, you do have options.
1. Have MC open and on Movies.
In Explorer, Click and drag the new movie over top of the list of movies in MC, and drop. MC will just scrape the new movie.
2. This is what I do. MC only has a temp folder as the root movie folder. All new movies go into this folder and get scraped.
Once I'm happy with the scraped data, I use Explorer to cut and paste the movie from the Temp folder, into my Master Movie Folder.
3. Create a new profile, pointing to a Temp folder.
Scrape this folder for new movies, and when finished, Cut and Paste the new movies to your main Movie folder.
Switch between profiles. Create new profile from Preferences, Profile & Commands Tab.
Once there is more than one profile, you can switch between them from the Toolbar.
BTW, Drag and drop is supported for Movie List, TV List, Root Movie Folders, Root TV Folders and List of TV Series listbox.
