(2016-08-07, 04:42)vbat99 Wrote: [ -> ]yep, just copied and pasted into an existing nfo. Showed 1.0 pcm
Are you saying the issue has been fixed?
The section you asked me to paste does not represent what was scraped, I added "1" channel to the NFO after the movie was scraped.
So your saying the original nfo had only
<audio>
<language>ita</language>
<DefaultTrack>Yes</DefaultTrack>
<codec>PCM</codec>
<channels></channels>
<bitrate>1 152 kb/s</bitrate>
</audio>
So <channels> was empty?
Hmmm, so I need to ensure that a Minimum value of "1" is stored if Mono.
Seems I need to source a PCM Mono file so I can test.....
Will be a fix in place for Mono PCM next release.
I was looking at the fanart tab and noticed that you can select thumb1, thumb2, etc.
What is the difference between a thumb and fanart? Pre- frodo?
It's to do with skins and also artwork downloader
Some skins look for thumb named images, artwork downloader looks for the fanart folder.
Great job on this release! The movie set addition is great! Thanks.
After having a little play, the new movie set feature isn't ready for prime time (at least for me). I still get 1 of unknown, 3 of 0, movies not in sets shows movie sets where I have none of those movies/set in my collection.
This was done with just the video files and scraped fresh. Other than this, everything else seems ok.
Hi @
bobrap
AnotherPhil has done extensive work in the movie set code between release, and I received an email saying there was more work needed doing.
I'll let you know an eta.
vbat99,
thanks for the update!
(2016-08-12, 22:34)vbat99 Wrote: [ -> ]Hi @bobrap
@AnotherPhil has done extensive work in the movie set code between release, and I received an email saying there was more work needed doing.
Yea, I forgot to say "I know this is Phil's deal". No big hurry. Really like the potential. Thanks to you and AnotherPhil!
vbat99,
I am assuming that the prior code grabbed the aspect ratio from the main page.
There are too many variables on the IMDb site in regards to aspect ratio. As you have it in this current version in some instances, it grabs the IMAX AR, and in others it grabs DVD version, VHS version etc.
The prior code had more accuracy than the one on this version.
(2016-08-13, 05:23)Edworld Wrote: [ -> ]vbat99,
Prior code was only from the main page. If current code does not suit, then I will reverse the changes so MC gets from Main page again.
vbat99,
thanks for trying
