New Release.
Media Companion 3.685b
New Feature: - Select TV root folder to scrape series from TheMovieDB.
MC 3.685b see the addition of selecting your TV Root Folder to scrape series from either TVDb, or from TMDB (TheMovieDb).
If the user selects to scrape series from TMDB, the series nfo is altered to scrape Actors for series and episodes from TMDB.
A fair amount of work has been done for TheMovieDB series and episode scraping to function correctly. But there are some minor limitations:
1. TMDB does not have Series Banners.
2. At this time, any series changed to TMDB, will only be able to get actors from TMDB.
3. Not all episodes have all external ID's loaded, so some episodes may be missing their unique ID, and/or IMDb Id.
From the TV Folder tab, users will now see three columns before the path of the TV Root folder.
Two check boxes, colums titled
A and
S, dropbox listing source scraper,
TVDb or
TMDb
A indicates active root folder - can be searched for new series (F7 key)<br>
S indicates Searchable for new episodes. If unselected, Series is affected root folder will be excluded when searching for new episodes, but will be included for Refresh All.<br>
TVDb - Legacy scraper.<br>
TMDb - Scrape series and episodes from TheMovieDB. Actors only retrieved from TheMovieDB.
Please note, I have tried to test all
edge cases, but know I can never account for all problems that arise.
Please, if you come across an issue, raise a Ticket on MediaCompanions SourceForge site, with step-by-step instructions to re-create the issue. If users can also zip and attach their config.xml and tvcache.xml it will help to test with the users settings.
New:- TV - Select TV Root folder for all series contained within to scrape from TheMovieDB (TMDB)
Fixed:- TV - Fix series and episode actors saving correctly with selected options.
- TV - Fix scrape series and empty plot returned.
- TV - Fix retrieving Writers from TVDb and TMDB.
- TV - Fix Tv genre Max - behave damn you!
- Movie - Fix if no playcount node or playcount node is empty from movie nfo, default to playcount to zero (unwatched).
- and other fixes that I forgot to annotate in the commits.
And, Please, if you experience any crashes, create a Ticket on Media Companion's SourceForge site
Feedback would be appreciated.
Download Link for MC 3.685b x86 & x64
Revision History
