(2018-03-04, 23:33)vbat99 Wrote: [ -> ]As Karellen mentioned your account is still in probation period, then it would be best open a ticket or discussion on SourceForge site. MC on SourceForge
There you can attached the cache file and we can progress with any issues found.
Okay so I opened that ticket
here.
hello, new here, just tested the tool for music videos, it works .. a bit, it looks like you can only force manually using english wiki, unfortunaly, I got french videos here, but they are also on english wiki...
But I found bugs, most of foreign chars are bugged from english wiki, and most of the time date isn't grabbed. ( exemple :
https://en.wikipedia.org/wiki/Bloqu%C3%A9 )
Anyway I can edit music video myself and it's already huge.
Now can you add youtube as a huge music videos source ? it may be not hosting real dates (it does for new one) but at least it offers screenshot and background.
Most of all... it's n°1 source for music videos, is it possible to make a whole grab tool video+infos ?
(2018-03-08, 11:11)ninjaw Wrote: [ -> ]hello, new here, just tested the tool for music videos, it works .. a bit, it looks like you can only force manually using english wiki, unfortunaly, I got french videos here, but they are also on english wiki...
But I found bugs, most of foreign chars are bugged from english wiki, and most of the time date isn't grabbed. ( exemple : https://en.wikipedia.org/wiki/Bloqu%C3%A9 )
I have done some work on the Music Video section, but at this time English is the only reliable language we can get data from Wiki.
As for Youtube...Not sure how we'd get data on Music Videos.
I am prepared to send some time in the Music Video sections to improve foreign characters from English Wiki, but I need to get a new release out ASAP.
Thanks for the new version!
I think I found a bug. When I click on any episode, it automatically changes case to all lower case.
Example:
(2018-03-12, 16:51)MonSoon12 Wrote: [ -> ]Thanks for the new version!
I can confirm this is a new bug with MC 3.698b
I'll investigate and let you know.
Example:
Found the issue was when I refactored episode code, I did not realize one of the routines changed reading the episode nfo to lowercase.
As this affects all text data from an episodes nfo, title, plot, actor names etc, I have pushed a new release now.
Thanks so much @
vbat99, appreciate so a quick turnaround from identifying the issue and pushing out a fix!
Hello Rob,
When I click on any movie and click on change movie in MC 3.699 I am getting the below error.
When i click on yes then MC stays otherwise closes when clicked on No.
Thanks John.
(2018-03-16, 01:28)john8546 Wrote: [ -> ]Hello Rob,
Thanks John.
Damn it. Another check I didn't add when I altered this sections code.
Apologies. I have a fix in place but it may have to wait for the next release.
hi is there a way to complete disable this tab so i can have more space, i never use that tab
thanks in advanced
(2018-03-16, 19:02)mata7 Wrote: [ -> ]hi is there a way to complete disable this tab so i can have more space, i never use that tab
thanks in advanced
You should be able to right-click anywhere in the filters, select
Configure Movie Filters and click on
Check/Uncheck All to deselect everything.
thank you for you help ronnie that did it
I have always wondered, is there a reason why Votes in the TV Shows section is un-editable/blanked out and the only way is to edit the .nfo file?
