vbat99
Quote:Are you saying MC is scraping with 0.0 rating and N/A in Votes? and this is coming from RT?
Yes, sometimes, but then I saw that if that's the case, it's also an entry on the rotten website, just without any ratings. Still have a look on it.
Quote:It may be possible to add the option to get TMDb votes if using the IMDb scraper.
That's great!
Quote:If I recall correctly if TMDb scraper and get IMDb rating, them both TMDB and IMDb get scraped and IMDb is set to Primary( or default = 'True')
Ah, ok, that means if scraped only with TMDB, only then have only the TMDB ratings in it.
Quote:The other entries in the nfo for Rating and Votes is the value from the default source, and yes is for compatability.
I have just tested.. last rating is really not needed by kodi anymore
So a kind of "Legacy" support for those still using a Kodi version under 17.
Quote:Yep, I'll be adding an option to save to set folder within the central folder.
Oh man, that means I can finally test the Movie Set Artwork Central Folder function. I imagine that this is not easy to programming.
If i do so ... will it differ from the options and the handling of the "normal usual" way?
By that I mean the tabs "Poster" and "Fanart" and "MovieSet" as well as the Artwork Indicator (under rescrape button).
Will i need to manually fill the folder (paste copy manual or new scraping)
Or would it be able to export existing artwork from the MovieSet parent folder to the central folder and vice versa?
Quote:If the movie was scraped by TMDb, then you should have at least TMDb ratings.
If TMDB and also option for IMDb Ratings selected, you'll TMDB, IMDB and Metacritic
But if you are using IMDb as the scraper, at this time you only get IMDb ratings and Metacritic. No TMDb ratings with IMDb scraper at this point in time.
You will get Rotten Tomato ratings if this option is selected in Common Preferences tab.
Also, Batch Rescrape has a new option Rotten Tomato which will scrape the Rotten Tomato ratings (Audience and Critics).
BTW, to get Rotten Tomato ratings, you will need to get your own OMDb API Key and add this into Media Companion.
I think you have to write that answer somewhere big. I think that will be some questions that are newcomers to MC. Maybe somehow restructure ratings management, I have no idea.
Edworld
Quote:Your dialogvideoinfo mod, is krypton or leia?
Please refer to my signature under my posts. But the .xml is custom coded, on mod it's looking bit differnt.
Quote:vbat99,
Assume you develop a webpage for ratings that has high participation. Scraping your site would be:
<rating name="vbat99critics" max="10">
<value>9.5</value>
<votes>227</votes>
</rating
Do you know if Kodi has code to accept ratings other than metacritics,tomato,moviedb and imdb?
$INFO[ListItem.Rating(vbat99critics)]
No, Kodi can only operate with these:
https://i.imgur.com/huPA6VU.png
And as you can see, all of them are supported in MC for a few days now - great!
Quote:My recommendation would be to eliminate the last 2 rows of the rating section since it is a double dip of data.
As Rob said, it's the "Legacy support" rating for versions older than Kodi17, cause the db system changed.
Quote:For existing movie nfo's... how can I rescrape to include rotten tomatoes (both), tmdb and metacritic?
New movies is not an issue, but existing I can't find a way
https://ibb.co/fNTLFK
Quote:edit: lastplayed is not saving a date
You have do to that first:
https://forum.kodi.tv/showthread.php?tid...pid2018144
it would even be on the wiki - please read:
https://sourceforge.net/p/mediacompanion...tusImport/
I have to admit, it does not work very well for me either...
try:
https://forum.kodi.tv/showthread.php?tid=164652
