(2019-02-20, 18:31)huttdes Wrote: [ -> ]Also if doing this I would have to alter a couple settings from Koldtoft's video for future movies
Quote:**2 checkmarks in Media Companion and 1 checkmark in ArtworkBeef
for future scrapings:
on (i forget also to look on the right side "If Movies in folder, save artwork as: off, off")
off
ArtworkBeef (if ever use as also as artwork downloader scraper)
@"chrissix" @
koldtoft
Do you guys have 'extras' in your library?
I have quite a few movies with extras... behind the scenes, making of, etc.
I have these in an 'extras' folder in each movie folder.
I forget which addon is necessary for this or what skins support them...
There are 3 extras Addons out there (One of them is banned on this platform) via the context menu should all work fine. If you also want to have it via DialogVideoInfo the skin must have implemented it (or implement it yourself)
But this is quite offtopic in this thread!
Your screenshots are convincing and I do not want to contradict you in any case. The user @
Angelinas has tried a few times over the SkinHelper to retrieve, without success.
https://forum.kodi.tv/showthread.php?tid...pid2766658
(Both, SkinHelper and Universal Movie Scraper are linked to OMDB)
As it seems it works on the Universal Movie Scraper.
Okay, you could really alienate PlotOutline for that. Ever thought of scrape everything in Kodi in the Universal Movie Scraper and then simply export the Kodi Database to .nfo.
(2019-02-20, 20:06)huttdes Wrote: [ -> ]Do you guys have 'extras' in your library?
No I have never worked with that. Sorry.
(2019-02-20, 18:19)chrissix Wrote: [ -> ]If you really want to be futureproof - yes
Just to clarify.
This is the proper settings for future proof / best practice artwork settings?
Ok I hope I nailed it this time.. I replaced the video with an updated version with a bunch of corrections.
(2019-02-22, 03:12)koldtoft Wrote: [ -> ]Ok I hope I nailed it this time.. I replaced the video with an updated version with a bunch of corrections.
One question: I followed the video's instructions completely but when I started rescraping my movies for the renaming process it did rename everything but left a copy of the old misnamed folder. For instance: Zardoz (1974) and a folder (old one) Zardoz - 1974. I cancelled the process because I don't want to have to delete over a 1000 slightly different but really duplicate folders.
Am I missing something?
This can't really be correct.
EDIT: It seems to be deleting the old renamed folders now after I restarted the program.
(2019-02-22, 08:45)melons2 Wrote: [ -> ] One question: I followed the video's instructions completely but when I started rescraping my movies for the renaming process it did rename everything but left a copy of the old misnamed folder. For instance: Zardoz (1974) and a folder (old one) Zardoz - 1974. I cancelled the process because I don't want to have to delete over a 1000 slightly different but really duplicate folders.
Hi Melons
I am not sure if it deletes folders "on the fly" or it waits till it's done scraping and then deletes the old folders. I always close down my folder when I need to auto rename them, as I assume it won't be able to rename/delete folders if I have them open/selected or have one of the files inside them open.
However, if this is a bug that you have and Media Companion 3.5 for some reason can't delete your folders, it should be fairly straight forward to delete them, yourself. Maybe you can search or sort your folders by date or size and delete all the old or empty ones in one go?
If you want to be sure it works. maybe try creating a test folder with 3-5 movies and scrape/rename them and see if it works as intended.
A really insightful and informative video for newcomers.
Especially the shown setup with the extended ratings is certainly very useful. This is not completely conclusive for many beginners at first
Since newbies find most of the initial difficulties always the same. Here are a few things that are worth a tutorial also:
- How to Organize Folder Structure (both convention ways) and MediaCompanion to get a clean Collection View + Collection artwork in Kodi. General handling with Movie Collections.
- How to prepare and handle alternative movie versions (extended, remastered, unrated,...) in MediaCompanion.
- How do I prepare MediaCompanion for the skin to get in Kodi in every movie/tvshow a graphics at MPAA aka certificate displayed.
- How do I prepare MediaCompanion for the skin that I get in every movie/tvshow a studio graphics displayed.
(2019-02-22, 11:08)koldtoft Wrote: [ -> ] (2019-02-22, 08:45)melons2 Wrote: [ -> ] One question: I followed the video's instructions completely but when I started rescraping my movies for the renaming process it did rename everything but left a copy of the old misnamed folder. For instance: Zardoz (1974) and a folder (old one) Zardoz - 1974. I cancelled the process because I don't want to have to delete over a 1000 slightly different but really duplicate folders.
Hi Melons
I ran a test as you suggested and it doesn't delete the old folders and with over 3000 this will be a problem if it renames even a fraction of those. Manually deleting them by date doesn't work because all folders show the new date, how (in Windows 10) would I organize by size or some other method to delete them? (this would still be a manual deletion nightmare)
Again presently 80% of my movies are structured like this: F:\Movies\Apollo 13 - 1995\Apollo 13 - 1995.avi\1. What would you recommend?
2. Where can I see parts 2 & 3 of your video tutorial?
(2019-02-22, 16:01)chrissix Wrote: [ -> ]- How to Organize Folder Structure (both convention ways) and MediaCompanion to get a clean Collection View + Collection artwork in Kodi. General handling with Movie Collections.
I would love to do beginner tutorials for some of those, but I would need some help because I don't don't know how half of those are done
Collections and alternative movie versions especially.
