Full Version: Custom playlist not finding playlist??
Hi. I have made a directory of live music videos. So no scrapers involved. I went through the directory queuing each video then saving the whole thing as a playlist called live.m3u
I would like to make a custome playlist, however when I go to "set playlist" on the custom playlist 1 option, the file is not shown.
It has been confirmed that through file manager that the file live.m3u exists in /home/profile/.xbmc/use data/playlists, However the custom playlist set option does not see it....
Any help please.....
David
(2012-04-20, 04:06)davidils20l Wrote: [ -> ]Hi. I have made a directory of live music videos. So no scrapers involved.
Hi David ,
xbmc need nfo file to load video into the librairy. You can create nfo file with a scraper or a software.
Before loading your playlist, you must generate nfo file and add your source with a scraper ( don't scan ) .
I use "XBMC Music Video NFO" (a french software) to create nfo file.
bye
Thanks..... I have done this before many years ago..... I completely forgot about no files.
Thanks for your advice...
All the best
David
