2015-09-02, 10:06
(2015-09-02, 00:58)ed_davidson Wrote: [ -> ]If you go to the kodi repo can you install any other addons?
I've tried downloading other addons and some download fine and others don't. Very weird.
(2015-09-02, 04:56)dmcjr22 Wrote: [ -> ]ive installed it multiple times in the last two days it works...try uninstalling and reinstall kodi
22:07:32 T:5664 NOTICE: Authentication successful.
22:07:32 T:5664 NOTICE: None
22:07:33 T:5664 NOTICE: script.xbmcbackup-1.0.6: Starting
22:07:33 T:5664 NOTICE: script.xbmcbackup-1.0.6: Local Dir: C:/Users/HTPC/AppData/Roaming/Kodi/
22:07:33 T:5664 NOTICE: script.xbmcbackup-1.0.6: Remote Dir: 201509212207/
22:07:33 T:5664 NOTICE: script.xbmcbackup-1.0.6: Mode - Backup
22:07:33 T:5664 NOTICE: script.xbmcbackup-1.0.6: Creating Files List
22:07:33 T:5664 NOTICE: script.xbmcbackup-1.0.6: Writing files to: 201509212207/
22:07:33 T:5664 NOTICE: script.xbmcbackup-1.0.6: Source: C:/Users/HTPC/AppData/Roaming/Kodi/
22:07:54 T:5664 NOTICE: script.xbmcbackup-1.0.6: Writing files to: 201509212207/custom_6a9a259c/
22:07:54 T:5664 NOTICE: script.xbmcbackup-1.0.6: Source: C:/Cinema Vision/
22:10:48 T:5664 NOTICE: script.xbmcbackup-1.0.6: Writing files to: /Kodi Backup/
22:10:48 T:5664 NOTICE: script.xbmcbackup-1.0.6: Source: C:/Users/HTPC/AppData/Roaming/Kodi/cache/
22:10:48 T:5664 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.MemoryError'>
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.xbmcbackup\default.py", line 73, in <module>
backup.run(mode)
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.xbmcbackup\resources\lib\backup.py", line 278, in run
fileCopied = self.backupFiles(fileManager.getFiles(),self.xbmc_vfs, self.remote_vfs)
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.xbmcbackup\resources\lib\backup.py", line 482, in backupFiles
wroteFile = dest.put(aFile,dest.root_path + aFile[len(source.root_path):])
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.xbmcbackup\resources\lib\vfs.py", line 396, in put
newFile.Upload()
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.xbmcbackup\resources\lib\pydrive\files.py", line 226, in Upload
self._FilesInsert(param=param)
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.xbmcbackup\resources\lib\pydrive\auth.py", line 54, in _decorated
return decoratee(self, *args, **kwargs)
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.xbmcbackup\resources\lib\pydrive\files.py", line 246, in _FilesInsert
metadata = self.auth.service.files().insert(**param).execute()
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.module.googleapi\lib\apiclient\discovery.py", line 750, in method
payload = media_upload.getbytes(0, media_upload.size())
File "C:\Users\HTPC\AppData\Roaming\Kodi\addons\script.module.googleapi\lib\apiclient\http.py", line 357, in getbytes
return self._fd.read(length)
MemoryError
(2015-09-26, 10:39)lazylimey Wrote: [ -> ]Hi I am using Backup successfully on Windows and Android.
two questions
Why don't the shortcuts on the confluence screen backup?
Why isn't the addon Data setting - set On - as a default in the settings?
Thanks for any reply
(2015-09-26, 12:15)pusb87 Wrote: [ -> ](2015-09-26, 10:39)lazylimey Wrote: [ -> ]Hi I am using Backup successfully on Windows and Android.
two questions
you need to copy the guisettings.xml file from your backup onto your new install whilst kodi isnt running
(2015-09-22, 05:46)OtheA Wrote: [ -> ]Hello. New user to Kodi and I've installed the backup plugin. I'm trying to backup to a Google drive and receive the below error:
Code:22:07:32 T:5664 NOTICE: Authentication successful.
backup.run(mode)
newFile.Upload()
MemoryError
Anybody have an idea of what I'm doing wrong?
(2015-09-30, 15:31)robweber Wrote: [ -> ]I'm just taking a guess here - the error is in the google libraries. The ones throwing the error are in the functions "media_upload.getbytes()" and "fd.read(length)". The error itself is a MemoryError.
I think a good educated guess here is that the file you are trying to upload is too large for the library, it is trying to get the file size of the payload for chunking, and you are running out of memory. Now your system itself probably isn't using all it's memory, but the memory allocated to python for such an operation is running out.
Are you compressing the backups? If so just try not doing that. If you aren't compressing then there is a file, or set of files, that is just too big for the library to handle.
