2012-04-22, 06:05
I've done some searching already and haven't found an answer to this. I access all my movies through smart playlists so I can have them divided into kids movies, concert movies, etc. The problem is that smart playlists do not order the movies the same as the regular library view. So if I set the order to "none" then they are out of order, and if I set it to "title" then they are in order, but all the movies that begin with "the" are grouped together even if I said not to in the settings. Is there a way to group the movies the same as the regular library view in a smart playlist?
edit: Solved. I had to select view by name instead of playlist from the viewtype options.
