2012-04-22, 13:40
Hello,
I've installed XBMCBuntu from a Unetbootin-created USB stick on a second Revo 3600, install went well (except that it tried to get updates from CD, which obvioulsy failed). Reboot will only show me the blinking cursor on a black screen.
I've found these instructions, since apparently, the right bootloader gets installed on the USB stick, and not the HDD:
sudo grub-install /dev/sda (replace 'a' with whatever HDD you want to boot from)
sudo update-grub
sudo reboot
I tried logging into Ubuntu to do that, but the "thing" (is it busybox?) I can boot in after pressing F12 and picking "boot from first hard drive" doesn't even know the commands sudo, update, and grub.
I have a feeling I'm doin something wrong here....any leads? I think the issue is that the right bootloader isn't loading from the HD, but I can't find a way to remedy that.
sudo update-grub
sudo reboot
