Full Version: Permissions
I'm trying to edit the advanced settings.xml, I can because the permissions are not set correctly.
I right click in mac osx and then click "info" on cyberduck, I can change the permissions of the folders and click apply but they don't change.
I then right click the actual adnacedsettings.xml file and I can again change the permissions but cannot apply them.
Any ideas?
Im running ATV 1 sorry, I tried running that command but came back with username error so I changed to atv:tav and it cam back with directory could not be found.
The atv1 runs a stripped down version of OS X and not iOS. Might be better having a search over here http://forum.xbmc.org/forumdisplay.php?fid=56 or someone else might answer but I dont use that platform myself so not too familiar with it.
