And on windows those are the same folder...
If you have having this issue please delete the folder
/home/xbmc/.xbmc/addons/plugin.video.crunchyroll-takeout/resources/language/english/
Please reply with the results, this has been corrected in the repo. No update at this time.
Yoshi after deleting the folder I can now see everything except the episode name/number............queue, anime, drama etc etc and the titles are all there, but when I click on a show, nothing.............the eps are there.........if I scroll through I see the thumbnail and can click and watch the episode, but I don't see a title.
Do you want another debug log?
I'm having problems with this app as well. Some videos won't play no matter how many times I try. It will say "working" and then nothing.
Here's my debug file. This is the first time I've uploaded one, so if the information you need isn't on there I'll try to upload another one:
http://xbmclogs.com/show.php?id=39367
Xngears, the log you submitted doesn't have the error.
But the error is most likely the new CDN which everyone is having a hard time with.
This is a known issue, I'm working on it.
That's good to know. Do you have a rough estimate when the update might be ready?
This app is definitely my favorite way to watch Crunchyroll, so I hope it gets fixed soon.
So there are 2 CDNs.
One is edgefcs.net, most videos are on than, and we can play them no problem.
The other is fplive.net, which has some usl voodoo that I haven't found yet
Attak on Titan ep 14 is on fplive.net
It seems none of the Attack on Titan episodes past 14 are going to play, probably because they are all on fplive.net.
I really do hope you find a workaround.
Watamote episodes past episode 3 seem affected as well.
Really hoping a fix will be found soon, since those are two of the shows I'm watching the most.
I have checked the attack on Titan and Watamoe videos previously mentioned and they both work on a kindle fire HD (Which was unable to play any videos prior to this version).
So far everything works perfectly. I cant complain
Don't suppose there's been an update on this player? I only ask because my trial is going to run out tomorrow. If I can't view all the videos off this app, I probably won't subscribe.
Thank you for all your efforts on this.
Seeing as the quality of the streaming on Xbox 360 is less good than is provided by this add-on, and Crunchyroll seems determined to keep breaking it, I'll probably just cancel my Crunchyroll sub.
Let me know if you think sending Crunchyroll a nastygram about this is worthwhile, or if you're prefer to stay off their radar.
OK, Bad news time.
Without going in to
[redacted] a large number of CR Videos will not play back.
There is nothing I can do to fix this issue. There is a known resolution to this issue.
(XBMC Info)
Quote:---DO NOT LINK OR POST ANY RESOLUTION TO THIS ISSUE---
Linking to or otherwise posting the fix could be a violation of the XBMC Forums T.o.S.
I have posted an update that bypasses this issue.
So we shouldn't talk about Xeebo's Handshake 10 patch, or the fact that there's a downloader that works on all videos, without resorting to Android streams, using said patched rtmpdump?
Hello and thanks for this addon, wanted to try it but when i add the repo and go into the repo it doesn't show anything, is there any problem at the moment or ?
