(2014-04-08, 02:10)yoshiofthewire Wrote: [ -> ]OK, so you need to import the zip file in to XBMC, then you will see a urlXL repo in XBMC, refresh the repo and then you should see the addon
I did put the contents of the zip, not the zip itself, in the abovementioned folder. As a result, I do see the repo. But, as I said before, the repo contains no addons, regardless of hitting refresh an arbitrary number of times. What am I missing here? Some banality I wonder?
The repo showed up on my first try, so this was not an "installation" issue. As it turns out, there's a rather hidden context menu which can only be invoked from outside the repo and has different options than the regular context menu. This one has an option that says "Force refresh" and this is the one that does the trick.
So, cheers and thanks!
Would like to add my experiences with this add-on, as I am a very happy user, but still miss some things and have some issues. I was wondering whether the re-write yoshiofthewire mentioned might benefit from this feedback.
First off, this add-on is the best way to enjoy your crunchyroll streams, especially on tablet/phone/OUYA. The default crunchyroll apps are lacking in functionality: videos are automatically stretched (without preservering Aspect Ratio) but most annoyingly there seems to be a lack of buffering support, causing streams to have heavy delays sometimes. Letting XBMC handle the streaming eliminates these issues.
But, even Crunchyroll Takeout is not without some (more minor) issues (on OUYA with a sideloaded xbmc). If I do not use alternative streaming, I get High Quality streams. However, as soon as I want to skip ahead or back, audio is skipped correctly but my video hangs on the last frame shown before skipping, and this problem persists until closing the video. If I do use alternative streaming, I of course have SD quality and every few minutes I get artifacts (where and old frame and new frame weirdly seem to blend). I have to pick two lesser options. I tried fiddeling with both crunchyroll takeout and playback settings, but can't seem to surpass this problem.
I will try my other XBMC build which should be more compatible with OUYA, so maybe OUYA is at fault here. I will definitely check out these problems on my Windows Laptop and Android Laptop and report back here with my findings.
After a 90% rewrite the Crunchyroll;xbmc is released to the world.
It has NOT been pushed to the repo yet.
It needs MORE TESTING, and you can help.
Things not yet decided:
1) For install reasons make this replace Crunchyroll Takeout or make it a new Plugin
2) If it should force a paid membership.
The plugin will NOT work if you don't have a free account.
Quote:The plugin will NOT work if you don't have a free account.
Do you mean that you need an account (regardless of being free or paid), or does it have to be free specifically?
I like to test, but how can I download it (as it has not been pushed to the repo)?
(2012-04-23, 07:17)yoshiofthewire Wrote: [ -> ]Disclaimer:
You will need a Crunchyroll account!
Install the attached Zip: Public Beta Install
*THIS HAS NOT BEEN TESTED WITH UPGRADES AT THIS POINT*
Right now any account will work. Just copy the what's in the zip into your %appdata%/XBMC/addins folder
Ok, so I started using the old, 0.7.7 something release since I was really dissapointed that CR does not have 720p on their Android app and using the PS3 app to watch all the new shows would skyrocket my electric bill, and XBMC for andoid is pretty much the same as the app: no 720p, so I installed j1nx linux beta2 on my dust collecting G-Box Midnight (I bought it before getting my LG Smart TV, but after I got it I stopped using it) and then installed the plugin; here's what happened:
-Wifi streaming kept buffering over and over every 2 seconds, but this seems to be more of an issue with the wifi device in the box, since my windows XBMC worked flawlessly on wifi
-Wired streaming works great, I'm even thinking/reconsidering to keep paying after the 14 day trial; just a couple of issues arised (don't know if they were already reported or not, didn't read the previous pages):
-like @
1312rene said: frame stops if you try to fast forward or rewind the video, funny thing is that if I skipped the stream by a minute using the right and left arrow buttons on my remote it kept playing without a sinch.
-if you pause the stream ant then resume the stream will not continue and exit after a few seconds. (this also happened on windows)
-after watching a couple of "Manga Artist" episodes I watched the latest "Baby Steps" episode and halfway the episode the subtitles started to look like squares and was't able to read anything; restarting the device fixed this one.
PS: j1nx linux for G-Box Midnight uses XBMC 12.0 Frodo
First off let me say thank you for this addon, it is the only thing keeping me from upgrading to gotham.
I just installed your addon on my test VM and I am getting a script error when I try and access my queue.
I will try and attach a debug log.
VMware 10
windows 7
XBMC v13 nightly 2014-04-30
Crunchyroll;xbmc v0.9.9.1 RC2
Debug Log:
http://pastebin.com/zxqtSb3P
Thank you.
orcus, I managed to reproduce the error here.
For now, before an actual fix, as a quick workaround you can go to the Addon Settings and change Queue Type from "Episodes" to "Series" that the error will not happen.
(2014-04-30, 22:33)le__ Wrote: [ -> ]orcus, I managed to reproduce the error here.
Wow, Thx man That worked. I will be trying this out more on my openelec system when I get the time to watch some anime. so far looks great.
This should be fixed in the latest update.
If there are no reported bugs in the next few days I will push this out to all users.
Because the new version needs a Crunchyroll Account, I am going to post my unused Guest passes in this thread.
First to get it, get's it. Good Luck!
[EXPIRED]
The next pass will be posted some time this weekend.
I should Have done this long ago....
9/9/2012 AA7U4JTNULX All-Access Guest Pass - 48 Hours Expired Dec 8, 2012 Not Redeemed Yet Expired
8/10/2012 LH46BRQ7AVR All-Access Guest Pass - 48 Hours Expired Nov 8, 2012 Not Redeemed Yet Expired
7/11/2012 6S4J9J36JG5 All-Access Guest Pass - 48 Hours Expired Oct 9, 2012 Not Redeemed Yet Expired
6/11/2012 UZW4MS83CYD All-Access Guest Pass - 48 Hours Expired Sep 9, 2012 Not Redeemed Yet Expired
5/12/2012 YUJTK9PBRRC All-Access Guest Pass - 48 Hours Expired Aug 10, 2012 Not Redeemed Yet Expired
4/12/2012 EFSYT54E8CF All-Access Guest Pass - 48 Hours Expired Jul 11, 2012 Not Redeemed Yet Expired
3/13/2012 GABQS6LHXEW All-Access Guest Pass - 48 Hours Expired Jun 11, 2012 Not Redeemed Yet Expired
2/2/2014 QZSU4VJVZWE All-Access Guest Pass - 48 Hours Expired May 3, 2014 Not Redeemed Yet Expired
1/3/2014 7R4S9FYVNH5 All-Access Guest Pass - 48 Hours Expired Apr 3, 2014 Not Redeemed Yet Expired
12/4/2013 988M7LPGV3S All-Access Guest Pass - 48 Hours Expired Mar 4, 2014 Not Redeemed Yet Expired
11/4/2013 PWDLFBL7ZZC All-Access Guest Pass - 48 Hours Expired Feb 2, 2014 Not Redeemed Yet Expired
10/5/2013 FPHQXAMNNZ9 All-Access Guest Pass - 48 Hours Expired Jan 4, 2014 Not Redeemed Yet Expired
8/5/2013 Z3B9WC8JE5M All-Access Guest Pass - 48 Hours Expired Nov 4, 2013 Not Redeemed Yet Expired
7/6/2013 6X9DZAQ6MW9 All-Access Guest Pass - 48 Hours Expired Oct 5, 2013 Not Redeemed Yet Expired
6/6/2013 8R4XACDKT6A All-Access Guest Pass - 48 Hours Expired Sep 5, 2013 Not Redeemed Yet Expired
5/7/2013 YXBJHYA6ZFV All-Access Guest Pass - 48 Hours Expired Aug 6, 2013 Not Redeemed Yet Expired
4/7/2013 RBFD3UFTVB4 All-Access Guest Pass - 48 Hours Expired Jul 7, 2013 Not Redeemed Yet Expired
3/8/2013 KX55VQEAMFQ All-Access Guest Pass - 48 Hours Expired Jun 7, 2013 Not Redeemed Yet Expired
2/6/2013 DCTJWMFMFRJ All-Access Guest Pass - 48 Hours Expired May 8, 2013 Not Redeemed Yet Expired
1/7/2013 K8EWGZL8FAE All-Access Guest Pass - 48 Hours Expired Apr 7, 2013 Not Redeemed Yet Expired
10/9/2012 VVJQJMWPD8E All-Access Guest Pass - 48 Hours Expired Jan 7, 2013 Not Redeemed Yet Expired
hi everyone, i am new to this and not very tech savy. i installed fusion on my xbmc box but i only hear audio when playing a tv show or movie, there is no video. can someone please help.
thanks mike
(2014-05-01, 04:09)mfiorino Wrote: [ -> ]hi everyone, i am new to this and not very tech savy. i installed fusion on my xbmc box but i only hear audio when playing a tv show or movie, there is no video. can someone please help.
thanks mike
Welcome mfiorino!
What are your running XBMC on?
What video are you trying to play?
Please post your log file:
[Click Here]
i am running it on my gbox and just any video from the movie or television apps. for example projectfreetv
