2014-06-26, 17:47
Hello Yoshi its my first time posting and i have to say that i love your work and i thank you for all of it but i still have problems when using the android version ( it works great on pc and mac tho )
I use the 2.0.5-beta on XBMC 12.3 on my Galaxy s4 and for some reason i cant open the plugin xbmc gives me the Script error window, heres the debugging log chunk that i think is relevant to the error ( im no expert on this so i might be posting something useless but if it is can you tell what i should post so you can help me please?)
DEBUG: Instantiating addon using automatically obtained id of "plugin.video.crunchyroll-takeout" dependent on version 2.1.0 of the xbmc.python api
14:43:08 T:2058822816 NOTICE: [PLUGIN] 'Crunchyrollxbmc: version 2.0.5' initialized!
14:43:09 T:1915198464 DEBUG: ------ Window Init (DialogBusy.xml) ------
14:43:09 T:1915198464 DEBUG: Window DialogBusy.xml was already loaded
14:43:09 T:1915198464 DEBUG: Alloc resources: 0.00m
14:43:09 T:2053104016 DEBUG: CFileCache::Open - opening <svn/trunk/addons.xml.md5> using cache
14:43:09 T:2053104016 DEBUG: CurlFile::Open(0x7b2b3698) http://kinkin-xbmc-repository.googlecode...ns.xml.md5
14:43:09 T:2053104016 INFO: - Created session to http://kinkin-xbmc-repository.googlecode.com
14:43:10 T:2053764744 INFO: CFileCache:rocess - Hit eof.
14:43:10 T:2053104016 DEBUG: CurlFile::Open(0x7aa62ef0) http://kinkin-xbmc-repository.googlecode...addons.xml
14:43:10 T:2058822816 DEBUG: POParser: loaded 38 strings from file /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/CrunchyXBMC-master/resources/language/English/strings.po
14:43:10 T:2058822816 NOTICE: Unexpected error:
14:43:10 T:2058822816 NOTICE: (<type 'exceptions.OSError'>, OSError(1, 'Operation not permitted'), <traceback object at 0x79bcdeb8>)
14:43:10 T:2058822816 ERROR: Exception
14:43:10 T:2058822816 ERROR: OSError
14:43:10 T:2058822816 ERROR: :
14:43:10 T:2058822816 ERROR: (1, 'Operation not permitted', '/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/userdata/addon_data/plugin.video.crunchyroll-takeout/cruchyXBMC.dir')
14:43:10 T:2058822816 ERROR: in
14:43:10 T:2058822816 ERROR: <bound method DbfilenameShelf.__del__ of {'session_id': '', 'API_LOCALE': 'enUS'}>
14:43:10 T:2058822816 ERROR: ignored
14:43:10 T:2058822816 ERROR: <bound method _Database.close of {'session_id': "S''\n.", 'API_LOCALE': "S'enUS'\np1\n."}>
14:43:10 T:1915198464 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
14:43:10 T:1915198464 DEBUG: Window DialogKaiToast.xml was already loaded
14:43:10 T:1915198464 DEBUG: Alloc resources: 0.03m
14:43:10 T:1999273064 DEBUG: CSoftAE::FinalizeSamples - Clamping buffer of 11288 samples
14:43:10 T:2058822816 INFO: Python script stopped
14:43:10 T:2043693136 DEBUG: - plugin exited prematurely - terminating
14:43:10 T:1915198464 DEBUG: waiting for python thread 9 (/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/CrunchyXBMC-master/default.py) to stop
14:43:10 T:1915198464 DEBUG: python thread 9 (/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/CrunchyXBMC-master/default.py) destructed
14:43:10 T:1915198464 ERROR: - Error getting plugin://plugin.video.crunchyroll-takeout/
14:43:10 T:1915198464 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.crunchyroll-takeout/) failed
14:43:10 T:1915198464 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
14:43:10 T:1915198464 DEBUG: ParentPath = []
14:43:10 T:2043693136 DEBUG: Recaching image '/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/CrunchyXBMC-master/fanart.jpg' to '7/7209bc80.jpg':
14:43:10 T:2043693136 DEBUG: cached image 'special://masterprofile/Thumbnails/7/7209bc80.jpg' size 1920x1080
14:43:10 T:2053104016 DEBUG: CFileCache::Open - opening <Eldorados/eldorado-xbmc-addons/raw/master/addons.xml.md5> using cache
14:43:10 T:2053104016 DEBUG: CurlFile::Open(0x7a8dd2c8) https://github.com/Eldorados/eldorado-xb...ns.xml.md5
14:43:10 T:2053104016 INFO: - Created session to https://github.com
14:43:11 T:2051576760 DEBUG: - took 408 ms to load special://masterprofile/Thumbnails/5/570e18c6.png
14:43:11 T:1915198464 DEBUG: Unfocus WindowID: 10025, ControlID: 550
14:43:11 T:1915198464 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
14:43:12 T:2058822816 INFO: CFileCache:rocess - Hit eof.
