You know, it was working this morning. I like this app better than the one from Playon, it's a shame.
I just pushed an update to Github that fixes this issue.
I'm looking at a new method to enable the plugin that would remove the use of your username and password.
Not done yet, but I the fix should be pushed out by this weekend.
(2015-04-24, 17:09)yoshiofthewire Wrote: [ -> ]I just pushed an update to Github that fixes this issue.
How would we be able to access the queue if we don't log in?
edit** Fix works by the way, kodi Helix 14.2.
If we can steal a bottle of Magic Sauce you will go to the CR activation page and enter the link code on your TV.
Like you do with the YouTube app.
(2015-04-24, 18:00)yoshiofthewire Wrote: [ -> ]If we can steal a bottle of Magic Sauce you will go to the CR activation page and enter the link code on your TV.
How would that even work? Their product activation process assumes a code that comes from a device. As far as I know a computer running Kodi doesn't have a code. Neither does a dumb Television like mine.
How it works with YouTube
1) Kodi sends a JSON statement to an URL with an API Key
2) YouTube replies with a activation code
3) Kodi displays the code on the screen
4) You go to Youtube.com/Activate and enter the code
5) Kodi asks YouTube if you activated the device
6) YouTube responds with a secret for the player.
In this case replace YouTube with Crunchyroll ... if we can get a bottle of magic sauce.
What does magic sauce taste like? Garum
can't get into crunchyroll on kodi
Please fully explain the issue.
What error message are you getting?
Please note that all builds before 2.1.2 are non-functional at this time.
(2015-04-24, 21:24)yoshiofthewire Wrote: [ -> ]How it works with YouTube
Okay, so I just tried that with the Youtube app. I didn't know that's how it worked, I assumed you put in your login.
So, the special sauce you're talking about is finding a device signature to use that Crunchyroll would recognize as cooperate with?
OK, let us start from the top.
That was an example of how I hope things to work in the future.
... right now it is broken.
There is an update to fix it, that I have submitted, but has yet to have been pulled.
So, you just have to wait
OK, so in testing of the new build ... the video skipping is MUCH worse.
Yeah, got to work on that.
I pulled the one from Github yesterday, it's working fine. No skipping under kodi 14 helix.
Yeah, but skip backward is broken.
It's working for me. What I have experienced in the past has been that if XBMC/Kodi reports that you skipped 30 seconds, it's actually only 3 seconds. if I type in 30, then the arrow key, I get 30. Up and down gets 10 minutes, which is correct.
2.1.2 was accepted, so update if you are still seeing errors.
