Full Version: Crunchyroll [DMCA Takedown]
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
Hi yoshi
Any updates? Updated list still shows in alphabetic order, and doing the change you mentioned a couple pages back didn't work
(2016-01-17, 21:27)Lusanagi Wrote: [ -> ]I use unlocator and have it configured on my router.
Works transparently (although you may need to delete eve data folder mentioned by DarkSchneider for the us only series to appear).
Unfortunately is not working for me. Not working even for PC.
The proxy is working fine on PC Firefox, but not on the KODI plugin, it shows the content, but does not play.
Constant problems with buffering, blurred video image and randomly pausing video. When will you add proper preloading and prebuffering? Add-on is useless without actual preload, advanced settings do not help at all.
Hi. 2 noob questions
1. Is there any way (finally) to add series to the Kodi library?
2. If not, There will be anytime?
Hey. So I tried the new Krypton release and the plugin keeps crashing. I'm on OSX.
Are you working on making it work for the new alpha or waiting for the final release?
Cheers.
Just how does it crash? And what version are you using and from what source?
The most likely three things however (assuming you run addon v.2.2.1)
1) It crashes on login - remove the file crunchyPickle from the userdata/addon_data/<plugin_name>/ directory
2) It crashes when you list the queue but works otherwise - most likely the issue fixed in git (see first post in this thread to find the git)
3) Crashes in other circumstance/other way - a logfile and description of which version you use, how you installed it, and what you tried to do when it crashed (specific step) would be neat.
I have a longstanding issue on multiple platforms and versions where the total video time displayed is always shorter than the actual episode. An episode that is really 23:42 shows as 23:10, and episode that's 24:05 shows as 23:06. Once the running time hits the total time the total time starts counting up with the running time and it plays to the end but it makes seeking near the end of the episode really weird. Is there any way to fix this?
The total time issue is an intersting one.. we actually get that time from two different places
1) Server reports "duration" - this one is correct (and is reported at TotalTime by the plugin to kodi)
2) Kodi actually reads the metadeta in the final playlist file - this is the shorter time that kodi insists on displaying
The issue seems to be that kodi inists on using 2 regardless of what duration, totaltime or runtime is set to (when playing a playlist)
(2016-07-15, 14:03)AluminumGriffin Wrote: [ -> ]Just how does it crash? And what version are you using and from what source?
The entire Kodi app crashes to the desktop when I click the Crunchyroll addon to open it. I am using the Krypton alpha 2 release from the kodi.tv download page and I downloaded the addon from the default repository through the Kodi interface. I am running the latest version of MacOS.
I tried removing the pickle but it didn't work. Here's a log file from a fresh install of Kodi and the addon:
17:00:00 T:140735149666304  NOTICE: special://profile/ is mapped to: special://masterprofile/
17:00:00 T:140735149666304  NOTICE: -----------------------------------------------------------------------
17:00:00 T:140735149666304  NOTICE: Starting Kodi (17.0-ALPHA2 Git:2016-06-30-f3ca4ea). Platform: OS X x86 64-bit
17:00:00 T:140735149666304  NOTICE: Using Release Kodi x64 build
17:00:00 T:140735149666304  NOTICE: Kodi compiled Jun 30 2016 by Clang 6.0 (clang-600.0.56) for OS X x86 64-bit version 10.8.0 (1080)
17:00:00 T:140735149666304  NOTICE: Running on Apple Inc. MacBookPro12,1 with OS X 10.11.6, kernel: Darwin x86 64-bit version 15.6.0
17:00:00 T:140735149666304  NOTICE: Host CPU: Intel(R) Core(TM) i5-5257U CPU @ 2.70GHz, 4 cores available
17:00:00 T:140735149666304  NOTICE: special://xbmc/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
17:00:00 T:140735149666304  NOTICE: special://xbmcbin/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
17:00:00 T:140735149666304  NOTICE: special://masterprofile/ is mapped to: /Users/ianrobinson/Library/Application Support/Kodi/userdata
17:00:00 T:140735149666304  NOTICE: special://home/ is mapped to: /Users/ianrobinson/Library/Application Support/Kodi
17:00:00 T:140735149666304  NOTICE: special://temp/ is mapped to: /Users/ianrobinson/.kodi/temp
17:00:00 T:140735149666304  NOTICE: special://logpath/ is mapped to: /Users/ianrobinson/Library/Logs
17:00:00 T:140735149666304  NOTICE: special://frameworks/ is mapped to: /Applications/Kodi.app/Contents/Libraries
17:00:00 T:140735149666304  NOTICE: The executable running is: /Applications/Kodi.app/Contents/MacOS/Kodi
17:00:00 T:140735149666304  NOTICE: Local hostname: Ians-MacBook-Pro.local
17:00:00 T:140735149666304  NOTICE: Log File is located: /Users/ianrobinson/Library/Logs//kodi.log
17:00:00 T:140735149666304  NOTICE: load settings...
17:00:00 T:140735149666304 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
17:00:00 T:140735149666304 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
17:00:00 T:140735149666304  NOTICE: Found 1 Lists of Devices
17:00:00 T:140735149666304  NOTICE: Enumerated DARWINOSX devices:
17:00:00 T:140735149666304  NOTICE:     Device 1
17:00:00 T:140735149666304  NOTICE:         m_deviceName      : default
17:00:00 T:140735149666304  NOTICE:         m_displayName     : Default
17:00:00 T:140735149666304  NOTICE:         m_displayNameExtra: HDMI
17:00:00 T:140735149666304  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
17:00:00 T:140735149666304  NOTICE:         m_channels        : FL,FR
17:00:00 T:140735149666304  NOTICE:         m_sampleRates     : 48000,44100,32000
17:00:00 T:140735149666304  NOTICE:         m_dataFormats     : AE_FMT_S24LE3,AE_FMT_S16LE
17:00:00 T:140735149666304  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
17:00:00 T:140735149666304  NOTICE:     Device 2
17:00:00 T:140735149666304  NOTICE:         m_deviceName      : Built-in Output:stream0
17:00:00 T:140735149666304  NOTICE:         m_displayName     : Built-in Output
17:00:00 T:140735149666304  NOTICE:         m_displayNameExtra: Internal Speakers
17:00:00 T:140735149666304  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
17:00:00 T:140735149666304  NOTICE:         m_sampleRates     : 96000,88200,48000,44100
17:00:00 T:140735149666304  NOTICE:         m_dataFormats     : AE_FMT_S24LE3,AE_FMT_S16LE,AE_FMT_FLOAT
17:00:00 T:140735149666304  NOTICE:         m_streamTypes     : No passthrough capabilities
17:00:00 T:140735149666304  NOTICE:     Device 3
17:00:00 T:140735149666304  NOTICE:         m_deviceName      : HDMI:stream0
17:00:00 T:140735149666304  NOTICE:         m_displayName     : HDMI
17:00:00 T:140735149666304  NOTICE:         m_displayNameExtra: SONY TV
17:00:00 T:140735149666304  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
17:00:00 T:140735149666304  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:00:00 T:140735149666304  NOTICE: Default Video Player: VideoPlayer
17:00:00 T:140735149666304  NOTICE: Default Audio Player: paplayer
17:00:00 T:140735149666304  NOTICE: Enabled debug logging due to GUI setting (2)
17:00:00 T:140735149666304  NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
17:00:00 T:140735149666304  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:00:00 T:140735149666304  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:00:00 T:140735149666304   DEBUG: CPlayerCoreConfig::<ctor>: created player VideoPlayer
17:00:00 T:140735149666304   DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: mms/udp
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
17:00:00 T:140735149666304   DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
17:00:00 T:140735149666304  NOTICE: Loaded playercorefactory configuration
17:00:00 T:140735149666304  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:00:00 T:140735149666304  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:00:00 T:140735149666304    INFO: creating subdirectories
17:00:00 T:140735149666304    INFO: userdata folder: special://masterprofile/
17:00:00 T:140735149666304    INFO: recording folder:
17:00:00 T:140735149666304    INFO: screenshots folder:
17:00:00 T:140735149666304  NOTICE: Running database version Addons26
17:00:00 T:140735149666304   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-x86-osx.so)
17:00:00 T:140735149666304   DEBUG: Loading: /Applications/Kodi.app/Contents/Resources/Kodi/system/libcpluff-x86-osx.so
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in resource.images.weathericons.default has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.nosefart has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.vbox has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.timidity has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in plugin.video.crunchyroll-takeout has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in visualization.fishbmc has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in kodi.peripheral has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in kodi.guilib has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.modplug has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in adsp.basic has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in peripheral.joystick has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in kodi.adsp has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audioencoder.xbmc.builtin.wma has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audioencoder.vorbis has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in adsp.biquad.filters has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in visualization.projectm has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in game.controller.default has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audioencoder.wav has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in kodi.game has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in visualization.shadertoy has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in service.xbmc.versioncheck has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in inputstream.rtmp has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audioencoder.flac has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.hdhomerun has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in screensaver.pingpong has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in skin.estouchy has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in inputstream.mpd has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.demo has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.sidplay has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.pctv has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in inputstream.smoothstream has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in kodi.inputstream has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in visualization.goom has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audioencoder.xbmc.builtin.aac has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.vgmstream has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.stsound has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in visualization.spectrum has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.stalker has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.snesapu has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in script.xbmc.debug.log has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in audioencoder.lame has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in adsp.freesurround has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.confluence has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.filmon has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Plug-in skin.estuary has been installed.'
17:00:00 T:140735149666304   DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
17:00:00 T:140735149666304  NOTICE: ADDONS: Using repository repository.xbmc.org
17:00:00 T:140735149666304   DEBUG: ADDON: Dll Initializing - InputStream MPEG DASH
17:00:00 T:140735149666304   DEBUG: SECTION:LoadDLL(/Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.mpd/inputstream.mpd.1.1.3.dylib)
17:00:00 T:140735149666304   DEBUG: Loading: /Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.mpd/inputstream.mpd.1.1.3.dylib
17:00:00 T:140735149666304   DEBUG: AddOnLog: InputStream MPEG DASH: libXBMC_addon successfully loaded
17:00:00 T:140735149666304   DEBUG: AddOnLog: InputStream MPEG DASH: ADDON_Create()
17:00:00 T:140735149666304   DEBUG: AddOnLog: InputStream MPEG DASH: ADDON_Destroy()
17:00:00 T:140735149666304   DEBUG: SECTION:UnloadDll(/Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.mpd/inputstream.mpd.1.1.3.dylib)
17:00:00 T:140735149666304    INFO: ADDON: Dll Destroyed - InputStream MPEG DASH
17:00:00 T:140735149666304   DEBUG: ADDON: Dll Initializing - RTMP Input
17:00:00 T:140735149666304   DEBUG: SECTION:LoadDLL(/Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.rtmp/inputstream.rtmp.1.0.0.dylib)
17:00:00 T:140735149666304   DEBUG: Loading: /Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.rtmp/inputstream.rtmp.1.0.0.dylib
17:00:00 T:140735149666304   DEBUG: AddOnLog: RTMP Input: InputStream.rtmp: ADDON_Create()
17:00:00 T:140735149666304   DEBUG: AddOnLog: RTMP Input: InputStream.rtmp: ADDON_Destroy()
17:00:00 T:140735149666304   DEBUG: SECTION:UnloadDll(/Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.rtmp/inputstream.rtmp.1.0.0.dylib)
17:00:00 T:140735149666304    INFO: ADDON: Dll Destroyed - RTMP Input
17:00:00 T:140735149666304   DEBUG: ADDON: Dll Initializing - InputStream SmoothStreamingMedia
17:00:00 T:140735149666304   DEBUG: SECTION:LoadDLL(/Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.smoothstream/inputstream.smoothstream.1.1.0.dylib)
17:00:00 T:140735149666304   DEBUG: Loading: /Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.smoothstream/inputstream.smoothstream.1.1.0.dylib
17:00:00 T:140735149666304   DEBUG: AddOnLog: InputStream SmoothStreamingMedia: ADDON_Create()
17:00:00 T:140735149666304   DEBUG: AddOnLog: InputStream SmoothStreamingMedia: ADDON_Destroy()
17:00:00 T:140735149666304   DEBUG: SECTION:UnloadDll(/Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.smoothstream/inputstream.smoothstream.1.1.0.dylib)
17:00:00 T:140735149666304    INFO: ADDON: Dll Destroyed - InputStream SmoothStreamingMedia
17:00:00 T:123145308819456   DEBUG: Thread ActiveAE start, auto delete: false
17:00:00 T:123145309356032   DEBUG: Thread AESink start, auto delete: false
17:00:00 T:123145309356032    INFO: CActiveAESink::OpenSink - initialize sink
17:00:00 T:123145309356032   DEBUG: CActiveAESink::OpenSink - trying to open device DARWINOSX:default
17:00:00 T:123145309356032  NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std::string &): Opening default device HDMI
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Finding stream for format AE_FMT_FLOAT
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (48000Hz) rated 1419.564697
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (44100Hz) rated 1508.000000
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (32000Hz) rated 282.376404
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 20-bit Signed Integer LE (48000Hz) rated 1418.564697
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 20-bit Signed Integer LE (44100Hz) rated 1507.000000
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 20-bit Signed Integer LE (32000Hz) rated 281.376404
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 16-bit Signed Integer LE (48000Hz) rated 1418.564697
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 16-bit Signed Integer LE (44100Hz) rated 1507.000000
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 16-bit Signed Integer LE (32000Hz) rated 281.376404
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [cac3] AC-3/DTS for S/PDIF LE (48000Hz) rated 0.000000
17:00:00 T:123145309356032   DEBUG: FindSuitableFormatForStream: Physical Format: [cac3] AC-3/DTS for S/PDIF LE (44100Hz) rated 0.000000
17:00:00 T:123145309356032   DEBUG: Initialize: Selected stream[0] - id: 0x003D, Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (44100Hz)
17:00:00 T:123145309356032   DEBUG: CCoreAudioDevice::SupportsMixing: Device mixing support : 'No'.
17:00:00 T:123145309356032   DEBUG: CCoreAudioStream::Open: Opened stream 0x003d.
17:00:00 T:123145309356032   DEBUG: Initialize: Previous Virtual Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
17:00:00 T:123145309356032   DEBUG: Initialize: Previous Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (44100Hz)
17:00:00 T:123145309356032   DEBUG: CCoreAudioStream::SetPhysicalFormat: Physical format for stream 0x003d. now active ([lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (44100Hz))
17:00:00 T:123145309356032   DEBUG: Initialize: New Virtual Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
17:00:00 T:123145309356032   DEBUG: Initialize: New Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (44100Hz)
17:00:00 T:123145309356032   DEBUG: GetAEChannelMap Engine requests layout FL,FR
17:00:00 T:123145309356032   DEBUG: GetAEChannelMap trying to map to stereo layout: [Left] [Right]
17:00:00 T:123145309356032   DEBUG: GetAEChannelMap mapped channels to layout FL,FR
17:00:00 T:123145309356032   DEBUG: Initialize: using buffer size: 16384 (0.046440 ms)
17:00:00 T:123145309356032   DEBUG: CActiveAESink::OpenSink - DARWINOSX Initialized:
17:00:00 T:123145309356032   DEBUG:   Output Device : Default
17:00:00 T:123145309356032   DEBUG:   Sample Rate   : 44100
17:00:00 T:123145309356032   DEBUG:   Sample Format : AE_FMT_FLOAT
17:00:00 T:123145309356032   DEBUG:   Channel Count : 2
17:00:00 T:123145309356032   DEBUG:   Channel Layout: FL,FR
17:00:00 T:123145309356032   DEBUG:   Frames        : 512
17:00:00 T:123145309356032   DEBUG:   Frame Size    : 8
17:00:00 T:140735149666304    INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BasePY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BaiduPY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Czech QWERTZ" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "French AZERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Korean ㄱㄴㄷ" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
17:00:00 T:140735149666304   DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
17:00:00 T:140735149666304  NOTICE: Setup SDL
17:00:00 T:140735149666304  NOTICE: Display 0 has name SONY TV
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 24.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 30.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 24.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 30.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 720 x 480 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 640 x 480 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 800 x 600 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1024 x 576 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1280 x 960 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1344 x 1008 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1344 x 756 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Found possible resolution for display 0 with 1600 x 900 @ 60.000000 Hz
17:00:00 T:140735149666304  NOTICE: Checking resolution 16
17:00:00 T:140735149666304  NOTICE: GL_VENDOR = Intel Inc.
17:00:00 T:140735149666304  NOTICE: GL_RENDERER = Intel(R) Iris(TM) Graphics 6100
17:00:00 T:140735149666304  NOTICE: GL_VERSION = 2.1 INTEL-10.14.73
17:00:00 T:140735149666304  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
17:00:00 T:140735149666304  NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
17:00:00 T:140735149666304   DEBUG: GetMode looking for suitable mode with 1920 x 1080 @ 60.000000 Hz on display 0
17:00:00 T:140735149666304   DEBUG: GetMode found a match!
17:00:01 T:140735149666304    INFO: GL: Maximum texture width: 16384
17:00:01 T:140735149666304    INFO: Previous line repeats 1 times.
17:00:01 T:140735149666304    INFO: GL: Enabling VSYNC
17:00:01 T:140735149666304    INFO: GL: Selected vsync mode 10
17:00:01 T:140735149666304    INFO: load keymapping
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/appcommand.xml
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/customcontroller.AppleRemote.xml
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/customcontroller.Harmony.xml
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/gamepad.xml
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/joystick.xml
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/keyboard.xml
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/mouse.xml
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/remote.xml
17:00:01 T:140735149666304    INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
17:00:01 T:140735149666304    INFO: GUI format 1920x1080, Display 1920x1080@ 60.00 - Full Screen
17:00:01 T:140735149666304   DEBUG: guilib: Fill viewport on change for solving rendering passes
17:00:01 T:140735149666304    INFO: CLangInfo: loading resource.language.en_gb language information...
17:00:01 T:140735149666304   DEBUG: trying to set locale to en_US.UTF-8
17:00:01 T:140735149666304    INFO: global locale set to en_US.UTF-8
17:00:01 T:140735149666304    INFO: CLangInfo: loading resource.language.en_gb language strings...
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 3680 strings from file resource://resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 44 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/adsp.basic/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 19 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/adsp.biquad.filters/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 16 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/adsp.freesurround/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 1 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/audiodecoder.timidity/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 1 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/audioencoder.flac/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 6 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/audioencoder.lame/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 6 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/audioencoder.vorbis/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 1 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/audioencoder.xbmc.builtin.aac/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 1 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/audioencoder.xbmc.builtin.wma/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 18 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/game.controller.default/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 6 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.mpd/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 5 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/inputstream.smoothstream/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 13 strings from file /Users/ianrobinson/Library/Application Support/Kodi/addons/metadata.album.universal/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 26 strings from file /Users/ianrobinson/Library/Application Support/Kodi/addons/metadata.artists.universal/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 7 strings from file /Users/ianrobinson/Library/Application Support/Kodi/addons/metadata.themoviedb.org/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 7 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/metadata.tvdb.com/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 1 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/peripheral.joystick/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 8 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.argustv/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 67 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.dvblink/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 34 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.dvbviewer/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 3 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.filmon/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 5 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.hdhomerun/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 68 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.hts/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 22 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.iptvsimple/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 71 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.mediaportal.tvserver/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 93 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.mythtv/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 28 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.nextpvr/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 2 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.njoy/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 8 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.pctv/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 43 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.stalker/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 16 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.vbox/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 69 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.vdr.vnsi/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 27 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.vuplus/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 70 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/pvr.wmc/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 10 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/screensaver.pingpong/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 1 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/screensaver.xbmc.builtin.dim/resources/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 21 strings from file /Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 12 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/visualization.fishbmc/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 15 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/visualization.projectm/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 15 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/visualization.spectrum/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 46 strings from file /Users/ianrobinson/Library/Application Support/Kodi/addons/plugin.video.crunchyroll-takeout/resources/language/English/strings.po
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 11 strings from file /Users/ianrobinson/Library/Application Support/Kodi/addons/script.xbmc.debug.log/resources/language/English/strings.xml
17:00:01 T:140735149666304   DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
17:00:01 T:140735149666304   DEBUG: LoadMappings - loaded node "CEC Adapter"
17:00:01 T:140735149666304   DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
17:00:01 T:140735149666304   DEBUG: LoadMappings - loaded node "iMON HID device"
17:00:01 T:140735149666304   DEBUG: USB Device Attach:Bluetooth USB Host Controller, 338690048
17:00:01 T:140735149666304   DEBUG: USB Device Attach:Logitech BT Mini-Receiver, 336789504
17:00:01 T:140735149666304   DEBUG: USB Device Attach:Logitech BT Mini-Receiver, 336723968
17:00:01 T:140735149666304   DEBUG: SECTION:LoadDLL(libcec.3.0.dylib)
17:00:01 T:140735149666304   DEBUG: Loading: /Applications/Kodi.app/Contents/Libraries/libcec.3.0.dylib
17:00:01 T:140735149666304   DEBUG: PERIPHERAL - CreateAddon - creating peripheral add-on instance 'Joystick Support'
17:00:01 T:140735149666304   DEBUG: ADDON: Dll Initializing - Joystick Support
17:00:01 T:140735149666304   DEBUG: SECTION:LoadDLL(/Applications/Kodi.app/Contents/Resources/Kodi/addons/peripheral.joystick/peripheral.joystick.1.1.0.dylib)
17:00:01 T:140735149666304   DEBUG: Loading: /Applications/Kodi.app/Contents/Resources/Kodi/addons/peripheral.joystick/peripheral.joystick.1.1.0.dylib
17:00:01 T:140735149666304   DEBUG: Calling TransferSettings for: Joystick Support
17:00:01 T:140735149666304   DEBUG: AddOnLog: Joystick Support: Setting "deadzone" set to 0.200000
17:00:01 T:123145311502336   DEBUG: Thread PeripBusCEC start, auto delete: false
17:00:01 T:123145312038912   DEBUG: Thread PeripBusAddon start, auto delete: false
17:00:01 T:140735149666304   DEBUG: SECTION:LoadDLL(libcurl.4.dylib)
17:00:01 T:123145312575488   DEBUG: Thread PeripEventScanner start, auto delete: false
17:00:01 T:140735149666304   DEBUG: Loading: /Applications/Kodi.app/Contents/Libraries/libcurl.4.dylib
17:00:01 T:140735149666304  NOTICE: Running database version Addons26
17:00:01 T:140735149666304   DEBUG: Initialize, updating databases...
17:00:01 T:140735149666304  NOTICE: Running database version ViewModes6
17:00:01 T:140735149666304  NOTICE: Running database version Textures13
17:00:01 T:140735149666304  NOTICE: Running database version MyMusic60
17:00:01 T:140735149666304  NOTICE: Running database version MyVideos106
17:00:01 T:140735149666304  NOTICE: Running database version TV29
17:00:01 T:140735149666304  NOTICE: Running database version Epg11
17:00:01 T:140735149666304   DEBUG: Initialize, updating databases... DONE
17:00:01 T:140735149666304  NOTICE: start dvd mediatype detection
17:00:01 T:140735149666304   DEBUG: DPMS: supported power-saving modes: OFF STANDBY
17:00:01 T:123145312653312   DEBUG: Thread DetectDVDMedia start, auto delete: false
17:00:01 T:123145312653312   DEBUG: Compiled with libcdio Version 0.90
17:00:01 T:123145307746304   DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
17:00:01 T:123145307746304   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
17:00:01 T:140735149666304   DEBUG: Activating window ID: 12997
17:00:01 T:140735149666304   DEBUG: ------ Window Init () ------
17:00:01 T:140735149666304    INFO: load splash image: /Applications/Kodi.app/Contents/Resources/Kodi/media/Splash.png
17:00:01 T:140735149666304    INFO: Unloading old skin ...
17:00:01 T:140735149666304    INFO:   load skin from: /Applications/Kodi.app/Contents/Resources/Kodi/addons/skin.estuary (version: 0.8.1)
17:00:01 T:140735149666304    INFO:   load fonts for skin...
17:00:01 T:140735149666304    INFO: Loading fonts from /Applications/Kodi.app/Contents/Resources/Kodi/addons/skin.estuary/1080i/Font.xml
17:00:01 T:140735149666304   DEBUG: LocalizeStrings: loaded 135 strings from file /Applications/Kodi.app/Contents/Resources/Kodi/addons/skin.estuary/language/resource.language.en_gb/strings.po
17:00:01 T:140735149666304    INFO: Loading skin includes from /Applications/Kodi.app/Contents/Resources/Kodi/addons/skin.estuary/1080i/includes.xml
17:00:01 T:140735149666304    INFO:   load new skin...
17:00:01 T:140735149666304    INFO: Loading user windows, path /Applications/Kodi.app/Contents/Resources/Kodi/addons/skin.estuary/1080i
17:00:01 T:140735149666304   DEBUG: Load Skin XML: 2.74ms
17:00:01 T:140735149666304    INFO:   initialize new skin...
17:00:01 T:140735149666304    INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
17:00:01 T:140735149666304   DEBUG: OpenBundle - Opened bundle /Applications/Kodi.app/Contents/Resources/Kodi/addons/skin.estuary/media/Textures.xbt
17:00:01 T:140735149666304    INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
17:00:01 T:140735149666304    INFO: Loading skin file: DialogNotification.xml, load type: LOAD_ON_GUI_INIT
17:00:01 T:140735149666304    INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
17:00:01 T:140735149666304    INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
17:00:01 T:140735149666304    INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
17:00:01 T:140735149666304    INFO: Loading resource://resource.uisounds.confluence/sounds.xml
17:00:01 T:140735149666304    INFO:   skin loaded...
17:00:01 T:140735149666304   DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
17:00:01 T:140735149666304 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:00:01 T:140735149666304    INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
17:00:01 T:140735149666304    INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
17:00:01 T:140735149666304    INFO: JSONRPC v7.16.0: Successfully initialized
17:00:01 T:140735149666304   DEBUG: ADDON: Starting service addons.
17:00:01 T:123145313189888   DEBUG: Thread LanguageInvoker start, auto delete: false
17:00:01 T:140735149666304   DEBUG: Activating window ID: 12999
17:00:01 T:140735149666304   DEBUG: ------ Window Init (Startup.xml) ------
17:00:01 T:140735149666304    INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
17:00:01 T:123145313189888    INFO: initializing python engine.
17:00:01 T:123145313189888   DEBUG: PYTHONHOME -> /Applications/Kodi.app/Contents/Libraries/
17:00:01 T:140735149666304   DEBUG: Activating window ID: 10000
17:00:01 T:123145313189888   DEBUG: PYTHONPATH -> /Applications/Kodi.app/Contents/Libraries/
17:00:01 T:140735149666304   DEBUG: ------ Window Deinit (Startup.xml) ------
17:00:01 T:140735149666304   DEBUG: ------ Window Init (Home.xml) ------
17:00:01 T:140735149666304    INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
17:00:01 T:123145313189888   DEBUG: CPythonInvoker(0, /Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck/service.py): start processing
17:00:01 T:123145313189888   DEBUG: -->Python Interpreter Initialized<--
17:00:01 T:123145313189888   DEBUG: CPythonInvoker(0, /Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck/service.py): the source file to load is "/Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck/service.py"
17:00:01 T:123145313189888   DEBUG: CPythonInvoker(0, /Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck/service.py): setting the Python path to /Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg:/Applications/Kodi.app/Contents/Libraries:/Applications/Kodi.app/Contents/Libraries/lib/python27.zip:/Applications/Kodi.app/Contents/Libraries/lib/python2.7:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-darwin:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac/lib-scriptpackages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-tk:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-old:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-dynload:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages
17:00:01 T:123145313189888   DEBUG: CPythonInvoker(0, /Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck/service.py): entering source directory /Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck
17:00:01 T:123145313189888   DEBUG: CPythonInvoker(0, /Users/ianrobinson/Library/Application Support/Kodi/addons/service.xbmc.versioncheck/service.py): instantiating addon using automatically obtained id of "service.xbmc.versioncheck" dependent on version 2.1.0 of the xbmc.python api
17:00:01 T:140735149666304   ERROR: Window Translator: Can't find window pvr
17:00:01 T:123145313726464   DEBUG: Thread JobWorker start, auto delete: true
17:00:01 T:123145313189888   DEBUG: Previous line repeats 2 times.
17:00:01 T:123145313189888   DEBUG: Version Check: Version 0.3.19 started
17:00:01 T:140735149666304    INFO: removing tempfiles
17:00:01 T:123145314263040   DEBUG: RunQuery took 11 ms for 0 items query: select * from movie_view  ORDER BY dateAdded desc, idMovie desc LIMIT 25
17:00:01 T:123145313726464   DEBUG: RunQuery took 13 ms for 0 items query: select * from movie_view  WHERE (movie_view.idFile  IN (SELECT DISTINCT idFile FROM bookmark WHERE type = 1))
17:00:01 T:140735149666304   DEBUG: CRepositoryUpdater: previous update at 07/27/2016 4:55:45 PM, next at 07/28/2016 4:55:45 PM
17:00:01 T:140735149666304  NOTICE: initialize done
17:00:01 T:140735149666304  NOTICE: Running the application...
17:00:01 T:140735149666304   DEBUG: no profile autoexec.py (/Users/ianrobinson/Library/Application Support/Kodi/userdata/autoexec.py) found, skipping
17:00:01 T:140735149666304   DEBUG: NetworkMessage - Starting network services
17:00:01 T:140735149666304  NOTICE: starting zeroconf publishing
17:00:01 T:140735149666304  NOTICE: starting upnp client
17:00:01 T:123145315336192   DEBUG: Thread Timer start, auto delete: false
17:00:01 T:123145314799616   DEBUG: RunQuery took 15 ms for 0 items query: select * from movie_view  WHERE ((movie_view.playCount IS NULL OR movie_view.playCount = 0))
17:00:01 T:140735149666304    INFO: JSONRPC Server: Successfully initialized
17:00:01 T:123145318555648   DEBUG: Thread EventServer start, auto delete: false
17:00:01 T:123145318555648  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
17:00:01 T:123145319092224   DEBUG: Thread TCPServer start, auto delete: false
17:00:01 T:123145318555648  NOTICE: UDP: Listening on port 9777
17:00:01 T:123145320165376   DEBUG: Thread JobWorker start, auto delete: true
17:00:01 T:123145314799616   DEBUG: RunQuery took 9 ms for 0 items query: select * from episode_view  ORDER BY dateAdded desc, idEpisode desc LIMIT 25
17:00:01 T:123145313726464   DEBUG: RunQuery took 14 ms for 0 items query: SELECT * FROM tvshow_view  WHERE watchedCount != 0 AND totalCount != watchedCount ORDER BY c00
17:00:01 T:123145320243200   DEBUG: Thread RSSReader start, auto delete: false
17:00:01 T:123145320243200   DEBUG: CurlFile::Open(0x700001119bc0) http://feeds.kodi.tv/xbmc
17:00:01 T:123145320243200    INFO: easy_aquire - Created session to http://feeds.kodi.tv
17:00:01 T:140735149666304   DEBUG: ------ Window Init (Pointer.xml) ------
17:00:01 T:123145314799616   DEBUG: GetRecentlyPlayedAlbums query: SELECT albumview.*, albumartistview.* FROM (SELECT idAlbum FROM albumview WHERE albumview.lastplayed IS NOT NULL ORDER BY albumview.lastplayed DESC LIMIT 25) as playedalbums JOIN albumview ON albumview.idAlbum = playedalbums.idAlbum JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum ORDER BY albumview.lastplayed DESC, albumartistview.iorder
17:00:01 T:123145313726464   DEBUG: GetRecentlyAddedAlbums query: SELECT albumview.*, albumartistview.* FROM (SELECT idAlbum FROM album WHERE strAlbum != '' ORDER BY idAlbum DESC LIMIT 25) AS recentalbums JOIN albumview ON albumview.idAlbum = recentalbums.idAlbum JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum ORDER BY albumview.idAlbum desc, albumartistview.iOrder
17:00:01 T:123145314263040   DEBUG: RunQuery took 14 ms for 0 items query: SELECT * FROM tvshow_view  WHERE ((CAST(tvshow_view.watchedcount as DECIMAL(5,1)) = 0)) AND ((CAST(tvshow_view.totalCount as DECIMAL(5,1)) > 0))
17:00:01 T:123145314799616   DEBUG: GetAlbumsByWhere query: SELECT albumview.* FROM albumview  WHERE albumview.strReleaseType = 'album'
17:00:01 T:123145313726464   DEBUG: GetArtistsByWhere query: SELECT artistview.* FROM artistview  WHERE (artistview.idArtist IN (SELECT album_artist.idArtist FROM album_artist ) OR artistview.idArtist IN (SELECT song_artist.idArtist FROM song_artist WHERE song_artist.idRole = 1)) and artistview.strArtist != '' and artistview.strArtist <> 'Various artists'
17:00:01 T:123145314263040   DEBUG: GetAlbumsByWhere query: SELECT albumview.* FROM albumview  WHERE (albumview.strReleaseType = 'album') AND (((CAST(albumview.iTimesPlayed as DECIMAL(5,1)) = 0)))
17:00:01 T:123145314799616   DEBUG: GetAlbumsByWhere - query took 2 ms
17:00:01 T:123145313726464   DEBUG: Previous line repeats 1 times.
17:00:01 T:123145313726464   DEBUG: Time to retrieve artists from dataset = 4
17:00:01 T:123145314799616   DEBUG: GetAlbumsByWhere query: SELECT albumview.* FROM albumview  WHERE (albumview.strReleaseType = 'album') AND (((CAST(albumview.iTimesPlayed as DECIMAL(5,1)) > 0)))
17:00:01 T:123145314799616   DEBUG: GetAlbumsByWhere - query took 0 ms
17:00:01 T:123145314263040   ERROR: GetDirectory - Error getting -
17:00:01 T:123145313726464   DEBUG: CMultiPathDirectory::GetDirectory(multipath://special%3A%2F%2Fprofile%2Fplaylists%2Fvideo/special%3A%2F%2Fprofile%2Fplaylists%2Fmixed/)
17:00:01 T:123145313726464   DEBUG: Getting Directory (special://profile/playlists/video)
17:00:01 T:123145314799616   DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
17:00:01 T:123145313726464   DEBUG: Getting Directory (special://profile/playlists/mixed)
17:00:01 T:123145313726464   DEBUG: CMultiPathDirectory::MergeItems, items = 0
17:00:01 T:123145314263040   DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:Kodi (Ians-MacBook-Pro.local) port:9090
17:00:01 T:123145314263040   DEBUG: CZeroconfOSX::doPublishService identifier: servers.eventserver type: _xbmc-events._udp name:Kodi (Ians-MacBook-Pro.local) port:9777
17:00:01 T:123145314799616   DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.*, songartistview.* FROM (SELECT idAlbum FROM album ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum = recentalbums.idAlbum JOIN songartistview ON songview.idSong = songartistview.idSong ORDER BY songview.idAlbum desc, songview.itrack, songartistview.iOrder
17:00:01 T:123145314799616   DEBUG: GetRecentlyAddedAlbums query: SELECT albumview.*, albumartistview.* FROM (SELECT idAlbum FROM album WHERE strAlbum != '' ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN albumview ON albumview.idAlbum = recentalbums.idAlbum JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum ORDER BY albumview.idAlbum desc, albumartistview.iOrder
17:00:01 T:123145314799616   DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
17:00:01 T:123145314799616   DEBUG: RunQuery took 0 ms for 0 items query: select * from movie_view  ORDER BY dateAdded desc, idMovie desc LIMIT 10
17:00:01 T:123145314799616   DEBUG: RunQuery took 0 ms for 0 items query: select * from episode_view  ORDER BY dateAdded desc, idEpisode desc LIMIT 10
17:00:01 T:123145314799616   DEBUG: RunQuery took 1 ms for 0 items query: select * from musicvideo_view  ORDER BY dateAdded desc, idMVideo desc LIMIT 10
17:00:01 T:123145314799616   DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
17:00:01 T:123145314799616   DEBUG: GetArtistsByWhere query: SELECT COUNT(DISTINCT artistview.idArtist) FROM artistview  WHERE (artistview.idArtist IN (SELECT album_artist.idArtist FROM album_artist ) OR artistview.idArtist IN (SELECT song_artist.idArtist FROM song_artist WHERE song_artist.idRole = 1)) and artistview.strArtist != '' and artistview.strArtist <> 'Various artists'
17:00:01 T:123145320243200   DEBUG: Got rss feed: http://feeds.kodi.tv/xbmc
17:00:01 T:123145320243200   DEBUG: RSS feed encoding: UTF-8
17:00:01 T:123145320243200   DEBUG: Parsed rss feed: http://feeds.kodi.tv/xbmc
17:00:01 T:123145320243200   DEBUG: CurlFile::Open(0x700001119bc0) http://feeds.kodi.tv/latest_xbmc_addons
17:00:02 T:123145320243200   DEBUG: Got rss feed: http://feeds.kodi.tv/latest_xbmc_addons
17:00:02 T:123145320243200   DEBUG: RSS feed encoding: UTF-8
17:00:02 T:123145320243200   DEBUG: Parsed rss feed: http://feeds.kodi.tv/latest_xbmc_addons
17:00:02 T:123145320243200   DEBUG: CurlFile::Open(0x700001119bc0) http://feeds.kodi.tv/updated_xbmc_addons
17:00:02 T:123145320243200   DEBUG: Got rss feed: http://feeds.kodi.tv/updated_xbmc_addons
17:00:02 T:123145320243200   DEBUG: Parsed rss feed: http://feeds.kodi.tv/updated_xbmc_addons
17:00:02 T:123145320243200   DEBUG: Thread RSSReader 123145320243200 terminating
17:00:04 T:140735149666304   DEBUG: ProcessMouse: trying mouse action leftclick
17:00:04 T:140735149666304   DEBUG: Activating window ID: 10025
17:00:05 T:140735149666304   DEBUG: ------ Window Deinit (Home.xml) ------
17:00:05 T:140735149666304   DEBUG: ------ Window Init (MyVideoNav.xml) ------
17:00:05 T:140735149666304    INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
17:00:05 T:140735149666304   ERROR: Window Translator: Can't find window pvr
17:00:05 T:123145314799616   ERROR: GetDirectory - Error getting
17:00:05 T:140735149666304   ERROR: Previous line repeats 1 times.
17:00:05 T:140735149666304   DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.crunchyroll-takeout/)
17:00:05 T:140735149666304   DEBUG:   ParentPath = [plugin://plugin.video.crunchyroll-takeout/]
17:00:05 T:140735149666304   ERROR: streamin_bufferwrap: can't stream in: requested 16777216 bytes, was read 5745 bytes
17:00:05 T:123145313726464   DEBUG: CAddonDatabase::SetLastUsed[plugin.video.crunchyroll-takeout] took 2 ms
17:00:05 T:140735149666304   ERROR: exception in CApplication::Process()
17:00:05 T:140735149666304   DEBUG: SECTION:UnloadDll(/Applications/Kodi.app/Contents/Resources/Kodi/addons/peripheral.joystick/peripheral.joystick.1.1.0.dylib)
17:00:05 T:140735149666304    INFO: ADDON: Dll Destroyed - Joystick Support
Seems like i crashes before the python interpreter even starts doing its thing.
A quick search for similar problems suggest either renaming or removing (I'd suggest renaming, since that will allow you to put it back if needed):
%APPDATA%\Kodi\cache
( on Mac that is /Users/<your_user_name>/Library/Application Support/Kodi/cache/ )
Does that fix it? (after a restart of kodi)
Nope. That log file was from a clean install. I deleted the entire Kodi folder in Application support before I reinstalled it.
Here's a couple of snippets of the Apple crash logs that pop up afterwards. I've gotten a couple of slightly different ones so far:
Process:               Kodi [724]
Path:                  /Applications/Kodi.app/Contents/MacOS/Kodi
Identifier:            org.xbmc.kodi
Version:               17.0.alpha2 (Git-20160630-f3ca4ea)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Kodi [724]
User ID:               501
Date/Time:             2016-07-30 03:35:36.945 -0400
OS Version:            Mac OS X 10.11.6 (15G31)
Report Version:        11
Time Awake Since Boot: 10000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       EXC_I386_GPFLT
Exception Note:        EXC_CORPSE_NOTIFY
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   org.xbmc.kodi                     0x000000010db24476 std::__1::__tree<std::__1::__value_type<int, RssSet>, std::__1::__map_value_compare<int, std::__1::__value_type<int, RssSet>, std::__1::less<int>, true>, std::__1::allocator<std::__1::__value_type<int, RssSet> > >::destroy(std::__1::__tree_node<std::__1::__value_type<int, RssSet>, void*>*) + 22
1   org.xbmc.kodi                     0x000000010db24481 std::__1::__tree<std::__1::__value_type<int, RssSet>, std::__1::__map_value_compare<int, std::__1::__value_type<int, RssSet>, std::__1::less<int>, true>, std::__1::allocator<std::__1::__value_type<int, RssSet> > >::destroy(std::__1::__tree_node<std::__1::__value_type<int, RssSet>, void*>*) + 33
2   org.xbmc.kodi                     0x000000010db23dd0 non-virtual thunk to CRssManager::OnSettingsUnloaded() + 48
3   org.xbmc.kodi                     0x000000010dbb882a CSettingsManager::OnSettingsUnloaded() + 90
4   org.xbmc.kodi                     0x000000010dbb335e CSettingsManager::Unload() + 302
5   org.xbmc.kodi                     0x000000010dbb3487 CSettingsManager::Clear() + 183
6   org.xbmc.kodi                     0x000000010d75bb86 CSettings::Uninitialize() + 2902
7   org.xbmc.kodi                     0x000000010d75afe4 CSettings::~CSettings() + 36
8   libsystem_c.dylib                 0x00007fff8a157463 __cxa_finalize_ranges + 345
9   libsystem_c.dylib                 0x00007fff8a157767 exit + 55
10  libdyld.dylib                     0x00007fff99a155b4 start + 8
Process:               Kodi [776]
Responsible:           Kodi [776]
User ID:               501
Date/Time:             2016-07-30 03:38:25.854 -0400
Report Version:        11
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Application Specific Information:
abort() called
*** error for object 0x7fd329e8f4f0: pointer being freed was not allocated
0   libsystem_kernel.dylib            0x00007fff99952f06 __pthread_kill + 10
1   libsystem_pthread.dylib           0x00007fff8d6ba4ec pthread_kill + 90
2   libsystem_c.dylib                 0x00007fff8a1566df abort + 129
3   libsystem_malloc.dylib            0x00007fff9c4e3041 free + 425
4   org.xbmc.kodi                     0x0000000102f024c2 std::__1::__tree<std::__1::__value_type<int, RssSet>, std::__1::__map_value_compare<int, std::__1::__value_type<int, RssSet>, std::__1::less<int>, true>, std::__1::allocator<std::__1::__value_type<int, RssSet> > >::destroy(std::__1::__tree_node<std::__1::__value_type<int, RssSet>, void*>*) + 98
5   org.xbmc.kodi                     0x0000000102f01dd0 non-virtual thunk to CRssManager::OnSettingsUnloaded() + 48
6   org.xbmc.kodi                     0x0000000102f9682a CSettingsManager::OnSettingsUnloaded() + 90
7   org.xbmc.kodi                     0x0000000102f9135e CSettingsManager::Unload() + 302
8   org.xbmc.kodi                     0x0000000102f91487 CSettingsManager::Clear() + 183
9   org.xbmc.kodi                     0x0000000102b39b86 CSettings::Uninitialize() + 2902
10  org.xbmc.kodi                     0x0000000102b38fe4 CSettings::~CSettings() + 36
11  libsystem_c.dylib                 0x00007fff8a157463 __cxa_finalize_ranges + 345
12  libsystem_c.dylib                 0x00007fff8a157767 exit + 55
13  libdyld.dylib                     0x00007fff99a155b4 start + 8
Hmm.. Those logs (btw, thanks for great logs) indicate there is a memory access error (aka - uninitialized pointer/not enough memory allocated).
Do video add-ons work otherwise? (If they do - it would be interesting to see a log of a functioning run, and the name of the plugin that works so I know what to canabilize for hints)
Reason for asking is that it seems that CPythonInvoker is successfully called earlier for a non-interactive script, but isn't called when calling crunchyroll-takeout.
I'm not sure what happened. I started this up, but I just got the click sound and nothing. If I go to popular or simulcast, they are blank. What is happening, it was working fine a couple of days ago? I also uninstalled it and reinstalled it but it still does the same thing.
So this problem seems to have solved itself. The only thing that changed was that I was no longer using the HDMI out to view my Mac. I don't know if this helps but I'll provide as much information as I can:
Initial setup: Mac laptop plugged in with the lid closed and viewed though an HDMI cable on my TV.
I used this setup to install the program and every time I tried to run it I got the above crash.
Fix?: I unplugged the HDMI and ran Kodi on my laptop screen and everything seems to run fine.
Here's the latest log:
20:37:28 T:140735250432000  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:37:28 T:140735250432000  NOTICE: -----------------------------------------------------------------------
20:37:28 T:140735250432000  NOTICE: Starting Kodi (17.0-ALPHA2 Git:2016-06-30-f3ca4ea). Platform: OS X x86 64-bit
20:37:28 T:140735250432000  NOTICE: Using Release Kodi x64 build
20:37:28 T:140735250432000  NOTICE: Kodi compiled Jun 30 2016 by Clang 6.0 (clang-600.0.56) for OS X x86 64-bit version 10.8.0 (1080)
20:37:28 T:140735250432000  NOTICE: Running on Apple Inc. MacBookPro12,1 with OS X 10.11.6, kernel: Darwin x86 64-bit version 15.6.0
20:37:28 T:140735250432000  NOTICE: Host CPU: Intel(R) Core(TM) i5-5257U CPU @ 2.70GHz, 4 cores available
20:37:28 T:140735250432000  NOTICE: special://xbmc/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
20:37:28 T:140735250432000  NOTICE: special://xbmcbin/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
20:37:28 T:140735250432000  NOTICE: special://masterprofile/ is mapped to: /Users/ianrobinson/Library/Application Support/Kodi/userdata
20:37:28 T:140735250432000  NOTICE: special://home/ is mapped to: /Users/ianrobinson/Library/Application Support/Kodi
20:37:28 T:140735250432000  NOTICE: special://temp/ is mapped to: /Users/ianrobinson/.kodi/temp
20:37:28 T:140735250432000  NOTICE: special://logpath/ is mapped to: /Users/ianrobinson/Library/Logs
20:37:28 T:140735250432000  NOTICE: special://frameworks/ is mapped to: /Applications/Kodi.app/Contents/Libraries
20:37:28 T:140735250432000  NOTICE: The executable running is: /Applications/Kodi.app/Contents/MacOS/Kodi
20:37:28 T:140735250432000  NOTICE: Local hostname: Ians-MacBook-Pro.local
20:37:28 T:140735250432000  NOTICE: Log File is located: /Users/ianrobinson/Library/Logs//kodi.log
20:37:28 T:140735250432000  NOTICE: load settings...
20:37:28 T:140735250432000 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
20:37:28 T:140735250432000 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
20:37:28 T:140735250432000  NOTICE: Found 1 Lists of Devices
20:37:28 T:140735250432000  NOTICE: Enumerated DARWINOSX devices:
20:37:28 T:140735250432000  NOTICE:     Device 1
20:37:28 T:140735250432000  NOTICE:         m_deviceName      : default
20:37:28 T:140735250432000  NOTICE:         m_displayName     : Default
20:37:28 T:140735250432000  NOTICE:         m_displayNameExtra: HDMI
20:37:28 T:140735250432000  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
20:37:28 T:140735250432000  NOTICE:         m_channels        : FL,FR
20:37:28 T:140735250432000  NOTICE:         m_sampleRates     : 48000,44100,32000
20:37:28 T:140735250432000  NOTICE:         m_dataFormats     : AE_FMT_S24LE3,AE_FMT_S16LE
20:37:28 T:140735250432000  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
20:37:28 T:140735250432000  NOTICE:     Device 2
20:37:28 T:140735250432000  NOTICE:         m_deviceName      : Built-in Output:stream0
20:37:28 T:140735250432000  NOTICE:         m_displayName     : Built-in Output
20:37:28 T:140735250432000  NOTICE:         m_displayNameExtra: Internal Speakers
20:37:28 T:140735250432000  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
20:37:28 T:140735250432000  NOTICE:         m_sampleRates     : 96000,88200,48000,44100
20:37:28 T:140735250432000  NOTICE:         m_dataFormats     : AE_FMT_S24LE3,AE_FMT_S16LE,AE_FMT_FLOAT
20:37:28 T:140735250432000  NOTICE:         m_streamTypes     : No passthrough capabilities
20:37:28 T:140735250432000  NOTICE:     Device 3
20:37:28 T:140735250432000  NOTICE:         m_deviceName      : HDMI:stream0
20:37:28 T:140735250432000  NOTICE:         m_displayName     : HDMI
20:37:28 T:140735250432000  NOTICE:         m_displayNameExtra: SONY TV
20:37:28 T:140735250432000  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:37:28 T:140735250432000  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:37:28 T:140735250432000  NOTICE: Default Video Player: VideoPlayer
20:37:28 T:140735250432000  NOTICE: Default Audio Player: paplayer
20:37:28 T:140735250432000  NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:37:28 T:140735250432000  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:37:28 T:140735250432000  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:37:28 T:140735250432000  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:37:28 T:140735250432000  NOTICE: Loaded playercorefactory configuration
20:37:28 T:140735250432000  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:37:28 T:140735250432000  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:37:28 T:140735250432000  NOTICE: Running database version Addons26
20:37:28 T:140735250432000  NOTICE: ADDONS: Using repository repository.xbmc.org
20:37:28 T:123145308819456  NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std::string &): Opening default device HDMI
20:37:28 T:140735250432000  NOTICE: Setup SDL
20:37:28 T:140735250432000  NOTICE: Display 0 has name SONY TV
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 24.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 30.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 24.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 30.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 720 x 480 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 640 x 480 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 800 x 600 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1024 x 576 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1280 x 960 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1344 x 1008 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1344 x 756 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Found possible resolution for display 0 with 1600 x 900 @ 60.000000 Hz
20:37:28 T:140735250432000  NOTICE: Checking resolution 16
20:37:28 T:140735250432000  NOTICE: GL_VENDOR = Intel Inc.
20:37:28 T:140735250432000  NOTICE: GL_RENDERER = Intel(R) Iris(TM) Graphics 6100
20:37:28 T:140735250432000  NOTICE: GL_VERSION = 2.1 INTEL-10.14.73
20:37:28 T:140735250432000  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
20:37:28 T:140735250432000  NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
20:37:29 T:140735250432000  NOTICE: Running database version Addons26
20:37:29 T:140735250432000  NOTICE: Running database version ViewModes6
20:37:29 T:140735250432000  NOTICE: Running database version Textures13
20:37:29 T:140735250432000  NOTICE: Running database version MyMusic60
20:37:29 T:140735250432000  NOTICE: Running database version MyVideos106
20:37:29 T:140735250432000  NOTICE: Running database version TV29
20:37:29 T:140735250432000  NOTICE: Running database version Epg11
20:37:29 T:140735250432000  NOTICE: start dvd mediatype detection
20:37:29 T:140735250432000 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:37:29 T:140735250432000   ERROR: Window Translator: Can't find window pvr
20:37:29 T:140735250432000  NOTICE: initialize done
20:37:29 T:140735250432000  NOTICE: Running the application...
20:37:29 T:140735250432000  NOTICE: starting zeroconf publishing
20:37:29 T:140735250432000  NOTICE: starting upnp client
20:37:29 T:123145318019072  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
20:37:29 T:123145318019072  NOTICE: UDP: Listening on port 9777
20:37:29 T:123145314263040   ERROR: GetDirectory - Error getting -
20:37:35 T:140735250432000   ERROR: Window Translator: Can't find window pvr
20:37:35 T:123145313726464   ERROR: GetDirectory - Error getting
20:37:39 T:123145302839296   ERROR: Previous line repeats 1 times.
20:37:39 T:123145302839296  NOTICE: CR: Queue: queue type is 1
20:37:39 T:123145302839296  NOTICE: CR: makeAPIRequest: get JSON
20:37:39 T:123145302839296  NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/queue.0.json
20:37:39 T:123145302839296  NOTICE: CR: makeAPIRequest: options = locale=enUS&media_types=anime%7Cdrama&version=2313.8&session_id=tjh2p1qmy5uufuvtmnselrl2rfn4vi23&fields=series.name%2Cseries.description%2Cseries.series_id%2Cseries.rating%2Cseries.media_count%2Cseries.url%2Cseries.publisher_name%2Cseries.year%2Cseries.portrait_image%2Cimage.large_url%2Cseries.landscape_image%2Cimage.full_url
20:37:42 T:123145302839296  NOTICE: CR: Queue: request['error'] = False
20:37:42 T:123145302839296  NOTICE: CR: Queue: has 103 series
20:38:08 T:123145303453696  NOTICE: CR: makeAPIRequest: get JSON
20:38:08 T:123145303453696  NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/list_collections.0.json
20:38:08 T:123145303453696  NOTICE: CR: makeAPIRequest: options = series_id=260265&sort=desc&version=2313.8&limit=0&locale=enUS&fields=collection.collection_id%2Ccollection.season%2Ccollection.name%2Ccollection.description%2Ccollection.complete%2Ccollection.media_count&session_id=tjh2p1qmy5uufuvtmnselrl2rfn4vi23
20:38:10 T:123145303453696  NOTICE: CR: makeAPIRequest: get JSON
20:38:10 T:123145303453696  NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/list_media.0.json
20:38:10 T:123145303453696  NOTICE: CR: makeAPIRequest: options = sort=asc&version=2313.8&limit=256&fields=media.episode_number%2Cmedia.name%2Cmedia.description%2Cmedia.media_type%2Cmedia.series_name%2Cmedia.available%2Cmedia.available_time%2Cmedia.free_available%2Cmedia.free_available_time%2Cmedia.playhead%2Cmedia.duration%2Cmedia.url%2Cmedia.screenshot_image%2Cimage.fwide_url%2Cimage.fwidestar_url%2Cseries.landscape_image%2Cimage.full_url&locale=enUS&collection_id=21533&session_id=tjh2p1qmy5uufuvtmnselrl2rfn4vi23
20:38:17 T:123145303453696  NOTICE: CR: makeAPIRequest: get JSON
20:38:17 T:123145303453696  NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/info.0.json
20:38:17 T:123145303453696  NOTICE: CR: makeAPIRequest: options = locale=enUS&fields=media.episode_number%2Cmedia.series_name%2Cmedia.name%2Cmedia.playhead%2Cmedia.description%2Cmedia.url%2Cmedia.stream_data&version=2313.8&media_id=652951&session_id=tjh2p1qmy5uufuvtmnselrl2rfn4vi23
20:38:17 T:123145303453696  NOTICE: CR: start_playback: url = http://www.crunchyroll.com/liveplaylist/videoencode_1418237.m3u8?key=aFBXN2g1NG5UdkVKckFhaWxITjl2cGxKR2RJPV97ImwiOjE0NDAwLCJvIjoiZW5VUyIsInMiOjI2MTMyMiwic2xpc3QiOiJcL3ZlMTQxODIzN1wvIiwidCI6MTQ2OTkyNTQ5NywidSI6IjE4ODA5NDUzIiwidiI6MX0&client=com.crunchyroll.iphone
20:38:17 T:123145303453696  NOTICE: CR: start_playback: Starting ...
20:38:18 T:140735250432000  NOTICE: VideoPlayer: Opening: http://www.crunchyroll.com/liveplaylist/videoencode_1418237.m3u8?key=aFBXN2g1NG5UdkVKckFhaWxITjl2cGxKR2RJPV97ImwiOjE0NDAwLCJvIjoiZW5VUyIsInMiOjI2MTMyMiwic2xpc3QiOiJcL3ZlMTQxODIzN1wvIiwidCI6MTQ2OTkyNTQ5NywidSI6IjE4ODA5NDUzIiwidiI6MX0&client=com.crunchyroll.iphone
20:38:18 T:140735250432000 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:38:18 T:123145303990272  NOTICE: Creating InputStream
20:38:18 T:123145303990272  NOTICE: Creating Demuxer
20:38:19 T:123145303990272  NOTICE: Opening stream: 0 source: 256
20:38:19 T:123145303990272  NOTICE: Creating video codec with codec id: 28
20:38:19 T:123145303990272  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:38:19 T:123145303990272  NOTICE: Creating video thread
20:38:19 T:123145303990272  NOTICE: Opening stream: 1 source: 256
20:38:19 T:123145303990272  NOTICE: Finding audio codec for: 86018
20:38:19 T:123145304526848  NOTICE: running thread: video_thread
20:38:19 T:123145303990272  NOTICE: Creating audio thread
20:38:19 T:123145305063424  NOTICE: running thread: CVideoPlayerAudio::Process()
20:38:19 T:123145305063424  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
20:38:19 T:123145303990272  NOTICE: CDVDMessageQueue::GetLevel() - can't determine level
20:38:19 T:140735250432000  NOTICE: Previous line repeats 2 times.
20:38:19 T:140735250432000  NOTICE: GL: Using CVBREF render method
20:38:19 T:140735250432000  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
20:38:19 T:140735250432000  NOTICE: GL: NPOT texture support detected
20:38:19 T:140735250432000  NOTICE: Using GL_TEXTURE_RECTANGLE_ARB
20:38:20 T:123145308819456  NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std::string &): Opening default device HDMI
20:38:20 T:140735250432000  NOTICE: GL: Using CVBREF render method
20:38:20 T:140735250432000  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
20:38:20 T:140735250432000  NOTICE: GL: NPOT texture support detected
20:38:20 T:123145303453696  NOTICE: CR: makeAPIRequest: get JSON
20:38:20 T:123145303453696  NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/log.0.json
20:38:20 T:123145303453696  NOTICE: CR: makeAPIRequest: options = version=2313.8&media_id=652951&locale=enUS&playhead=52&event=playback_status&session_id=tjh2p1qmy5uufuvtmnselrl2rfn4vi23
20:38:24 T:140735250432000  NOTICE: CVideoPlayer::CloseFile()
20:38:24 T:140735250432000  NOTICE: VideoPlayer: waiting for threads to exit
20:38:24 T:123145303990272  NOTICE: CVideoPlayer::OnExit()
20:38:24 T:123145303990272  NOTICE: Closing stream player 1
20:38:24 T:123145303990272  NOTICE: Waiting for audio thread to exit
20:38:24 T:123145305063424  NOTICE: thread end: CVideoPlayerAudio::OnExit()
20:38:24 T:123145303990272  NOTICE: Closing audio device
20:38:24 T:123145303990272  NOTICE: Deleting audio codec
20:38:24 T:123145303990272  NOTICE: Closing stream player 2
20:38:24 T:123145303990272  NOTICE: waiting for video thread to exit
20:38:24 T:123145304526848  NOTICE: thread end: video_thread
20:38:24 T:123145303990272  NOTICE: deleting video codec
20:38:24 T:140735250432000  NOTICE: VideoPlayer: finished waiting
20:38:24 T:140735250432000   ERROR: Control 50 in window 10025 has been asked to focus, but it can't
20:38:24 T:123145303990272  NOTICE: CR: makeAPIRequest: get JSON
20:38:24 T:123145303990272  NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/list_media.0.json
20:38:24 T:123145303990272  NOTICE: CR: makeAPIRequest: options = sort=asc&version=2313.8&limit=256&fields=media.episode_number%2Cmedia.name%2Cmedia.description%2Cmedia.media_type%2Cmedia.series_name%2Cmedia.available%2Cmedia.available_time%2Cmedia.free_available%2Cmedia.free_available_time%2Cmedia.playhead%2Cmedia.duration%2Cmedia.url%2Cmedia.screenshot_image%2Cimage.fwide_url%2Cimage.fwidestar_url%2Cseries.landscape_image%2Cimage.full_url&locale=enUS&collection_id=21533&session_id=tjh2p1qmy5uufuvtmnselrl2rfn4vi23
20:38:25 T:123145303453696  NOTICE: CR: start_playback: Finished logging: http://www.crunchyroll.com/liveplaylist/videoencode_1418237.m3u8?key=aFBXN2g1NG5UdkVKckFhaWxITjl2cGxKR2RJPV97ImwiOjE0NDAwLCJvIjoiZW5VUyIsInMiOjI2MTMyMiwic2xpc3QiOiJcL3ZlMTQxODIzN1wvIiwidCI6MTQ2OTkyNTQ5NywidSI6IjE4ODA5NDUzIiwidiI6MX0&client=com.crunchyroll.iphone
20:38:32 T:140735250432000   ERROR: GetDirectory - Error getting
20:38:32 T:140735250432000   ERROR: CGUIMediaWindow::GetDirectory( ) failed
20:39:24 T:123145319092224 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
20:39:53 T:140735250432000  NOTICE: Storing total System Uptime
20:39:53 T:140735250432000  NOTICE: Saving settings
20:39:53 T:140735250432000  NOTICE: Saving skin settings
20:39:53 T:140735250432000  NOTICE: stop all
20:39:53 T:140735250432000  NOTICE: stop player
20:39:53 T:140735250432000  NOTICE: ES: Stopping event server
20:39:53 T:140735250432000  NOTICE: stopping upnp
20:39:53 T:140735250432000  NOTICE: stopping zeroconf publishing
20:39:54 T:123145318019072  NOTICE: ES: UDP Event server stopped
20:39:54 T:140735250432000  NOTICE: stop dvd detect media
20:39:54 T:140735250432000  NOTICE: clean cached files!
20:39:54 T:140735250432000  NOTICE: closing down remote control service
20:39:54 T:140735250432000  NOTICE: stopped
20:39:54 T:140735250432000  NOTICE: destroy
20:39:54 T:140735250432000  NOTICE: unload skin
20:39:54 T:140735250432000 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
20:39:54 T:140735250432000  NOTICE: unload sections
20:39:54 T:140735250432000  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:39:54 T:140735250432000  NOTICE: application stopped...
I'm using my Mac through the HDMI again and it's working fine now so the only thing that I can think of is that the initial launch of KODI has problems with using external monitors.
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
