Full Version: Crunchyroll [DMCA Takedown]
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
[GitHub] DMCA Takedown Notice - https://github.com/Yoshiofthewire/CrunchyXBMC
Inboxx
GitHub Staff <[email protected]>Jun 11, 2018, 2:53 PM
to
Hi there,
I'm contacting you on behalf of GitHub Support because we've received a DMCA takedown notice regarding the following content:
You can view the notice and the details of the requested changes below.
In this case only certain files were identified as allegedly infringing. Since it's not possible to disable individual files within a GitHub repository, we're giving you a 24 hour opportunity to remove the content named in the takedown. Please follow the steps in the following article to remove the content from the history:
https://help.github.com/articles/remove-sensitive-data
Once you've done that, please reply to this message to confirm the change. If we don't hear from you that a change is made within the next 24 hours, we will need to disable the entire repository according to our GitHub DMCA Takedown Policy, which you can find here:
https://help.github.com/articles/dmca-takedown-policy/
If you believe your content on GitHub was mistakenly disabled by a DMCA takedown request, you have the right to contest the takedown by submitting a counter notice, as described on the DMCA Takedown Policy page.
PLEASE NOTE: It is important that you reply within 24 hours to confirm whether you have made the requested changes. If you do not, the repository will be disabled.
Remove Your MediaR , LLC
3308 Preston Rd Ste 350-157
Plano, TX 75093-7453
Ph: [private]
E-mail: [private]
6/8/2018 1:18:35 PM
re: https://www.github.com ( IP 192.30.253.113 )
ELECTRONIC NOTICE OF COPYRIGHT INFRINGEMENT
I, the undersigned, CERTIFY UNDER PENALTY OF PERJURY that I am an
agent authorized to act on behalf of http://www.crunchyroll.com whose
exclusive copyrights are being
infringed. The information in this notice is accurate.
Original Works & Copyright Holder(s):
CrunchyRoll Inc
835 Market St, Suite 700
San Francisco, CA 94103
ph: [private]
The works in question is copyrighted source code developed by CrunchyRoll
Inc.
Code has been reversed engineered, in bad faith, to disrupt owner's rights.
I have a good faith belief that the items or materials listed below are not
authorized
by the above owners, their agents or the law and therefore infringe the
owner's rights.
Please act expeditiously to remove or disable access to the infringing
material or items
listed as follows -- the download links and repos at the following URL(s):
https://github.com/Yoshiofthewire/Crunch...default.py
https://github.com/Yoshiofthewire/Crunch...hy_json.py
https://github.com/MattRK/Crunchyroll.bu...ceCode.pys
Truthfully,
/S/: [private]
X-Post to the CR Forms
It is with a heavy heart that I report that the Kodi (XBMC) plugin to view Crunchyroll has been hit with a DMCA take down.
Over the 4 years of it's existence it was used by (as of 2016) 5000 monthly active PAYING users.
A stress the Paying part because the version that was taken down, mostly unchanged since 2016, required a paid subscription.  While I feel the take down was in bad faith, if I was contacted I would have removed the plugin.
I HAVE DELETED THE REPO BEFORE MAKING THIS POST.
P.S. If we have to use the CR app or the VRV app, can you fix it so the login doesn't break once a month?
Thankx Bye
Oh well, thank you for all the effort on keeping this, real bummer it have to be deleted. Sad
(2018-06-11, 23:15)yoshiofthewire Wrote: [ -> ]P.S. If we have to use the CR app or the VRV app, can you fix it so the login doesn't break once a month?
 That's my only real complaint, TBH. I stopped using my Plex app a while ago because the mobile app + Chromecast is so easy and streams in 1080p. Oh well.
Best of luck to you with your future endeavors!
This sucks. I would have used this addon if crounchyroll had any good animes in germany. But well one option less, I guess.
I am not a lawyer, this is not legal advice, just my observations and links to online websites.
In 2013, Snapchat took down a reverse-engineered API library claiming it was a DMCA circumvention device, spawning a HackerNews thread (https://news.ycombinator.com/item?id=6083812 ).
The second-upvoted response (as well as the top) stated that (https://news.ycombinator.com/item?id=6084365 )
Quote:As with file formats, the notion that network protocols & APIs should ever be granted any type of protection and that no-one other than the creators should be able to write software that conforms to these protocols is ridiculous.
Snapchat, in my view, have every right to restrict who uses their service and in what manner - via standard mechanisms like API keys and login credentials. But preventing third-party implementations of protocols or APIs is so 90s. Oracle had a bit of trouble with this recently.
Anyway https://github.com/tlack/snaphax is back online (although it hasn't been updated since 2013).
I suspect this takedown request is baseless. Crunchyroll claims your independently written code is a copyright violation because it uses reverse-engineered APIs? I doubt APIs (even internal) are copyrightable, unless Oracle v. Google is used as precedent. Reverse engineering could be a violation of ToS/etc (I'm unsure about the details), but that's not what they complained about.
Anyway I have a Gitlab repository (with the premium-only restriction easily removed, much like the still-alive https://github.com/YePpHa/crunchyroll-html5 ). If my repo gets taken down as well, I'll switch to the HTML5 adblock extension. If that's removed as well, I'll stop using Crunchyroll.
Should I share the link to the original and/or patched code?
It was recently judged that APIs usage is not fair use (in the Unites States at least)
https://en.wikipedia.org/wiki/Oracle_Ame...oogle,_Inc.
(2018-06-13, 12:18)Karellen Wrote: [ -> ]https://torrentfreak.com/crunchyroll-add...nt-180613/
 Very lame that this happened. I hope the same doesn't happen to the Netflix addon.
I believe this takedown request is baseless, it does not use copyrighted code. Anyway if my mirror gets taken down, it gets taken down.
Nonetheless it seems you don't want this addon on the forums, so I don't really care if you delete it.
@jimbo1qaz
We have discussed your add-on.
In light of the recent action from Crunchyroll, we do not believe it would be a good idea to allow you to host the add-on here... even though we do agree with the unfairness of the takedown.
Keep your account active, as there is always the possibility of change in the future.
I've reached out to some folks I personally know over at Crunchyroll to get some clarification and was told this:
Quote:I imagine it was the client key that was grabbed from a client; and the takedown on github was requesting it to be removed.
Will ask internally if we can’t do something about it; would be nice if we had resources to build a more robust open API support for these sort of projects.
"The Digital Millennium Copyright Act (DMCA) makes it illegal to circumvent controls that prevent access to copyrighted material."
Specifically, look at https://www.eff.org/issues/coders/revers...g-faq#faq8
And they could consider an API key 'technology protection measures'. It's an unfortunate use of the law, but it seems it's on their side.
(2018-06-14, 16:16)keith Wrote: [ -> ]I've reached out to some folks I personally know over at Crunchyroll to get some clarification and was told this:
Well, the API key is hardcoded as string into the binaries of the apps.
You can just open it with a text editor and read the key in plaintext.
When Crunchyroll says that this is a protection measure, I'm sure passwords are saved unencrypted
Just because its super easy to circumvent does not mean it's not 'technology protection measures.
Sad really sad this happened
