Well nothing like a little bit of motivation to make a guy do something.... haven't been able to FTP into my xbox. This hasn't been an issue but eh, wanted to make sure. Installed xbmc4xbox 3.2 Under system/python I see python24. Thinking this is a good sign. I also went ahead and manually typed my username and password for crunchy into the settings.xml in the Crunchy Takeout addon. Still getting the same error.
So here we go - this is from my latest log file:
06:39:32 M: 33239040 NOTICE: -->Python Initialized<--
06:39:33 M: 31182848 NOTICE: [PLUGIN] 'CrunchyRollTakeout: version 0.6.0.5' initialized!
06:39:33 M: 31182848 ERROR: Error Type: exceptions.ImportError
06:39:33 M: 31182848 ERROR: Error Contents: No module named lib
06:39:33 M: 31178752 ERROR: Traceback (most recent call last):
File "Q:\plugins\video\Crunchyroll Takeout\default.py", line 15, in ?
from resources.lib import crunchy_main as crunchyrolltakeout
ImportError: No module named lib
06:39:34 M: 35209216 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://video/Crunchyroll Takeout/
06:39:34 M: 35209216 ERROR: CGUIMediaWindow::GetDirectory(plugin://video/Crunchyroll Takeout/) failed
06:39:34 M: 35151872 WARNING: old getenv from python.lib called, library check needed
06:39:34 M: 35151872 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
06:40:29 M: 36450304 WARNING: old getenv from python.lib called, library check needed
Previous line repeats 20 times.
____________________________________________________________________________________
This is from my old log:
6:25:04 M: 33361920 NOTICE: -->Python Initialized<--
06:25:05 M: 31318016 NOTICE: [PLUGIN] 'CrunchyRollTakeout: version 0.6.0.5' initialized!
06:25:05 M: 31318016 ERROR: Error Type: exceptions.ImportError
06:25:05 M: 31318016 ERROR: Error Contents: No module named lib
06:25:05 M: 31313920 ERROR: Traceback (most recent call last):
06:25:06 M: 35250176 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://video/Crunchyroll Takeout/
06:25:06 M: 35250176 ERROR: CGUIMediaWindow::GetDirectory(plugin://video/Crunchyroll Takeout/) failed
06:25:06 M: 35192832 WARNING: old getenv from python.lib called, library check needed
06:25:06 M: 35192832 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
06:25:35 M: 35815424 WARNING: old getenv from python.lib called, library check needed
Previous line repeats 49 times.
They look pretty much the same... No Module named lib.. am I missing a library when I just did a fresh reinstall? Thanks again for all the work and assistance!!
