I have been trying too add this plugin, but when I add the repo it is empty.
2013-02-17 13:00 Post: #108
If you are not seeing any addons in the repo you need to force refresh the repo and then the addon will show.
Please update to version 0.6.5 and select "Alternative Streaming Method "
This will playback the Android stream, this stream is SD only.
0.6.5 has been tested to work on a Nexus 4
After upgrading to 0.6.5 I'm getting the following error:
File "/home/xbmc/.xbmc/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_scraper.py", line 210, in __init__
self.base_path = os.path.join(xbmc.translatePath("special://masterprofile/"), "addon_data", os.path.basename(os.getcwd()))
OSError: (2, 'No such file or directory')
After putting in a temporary fix (changed it to: self.base_path = xbmc.translatePath("special://profile/addon_data/plugin.video.crunchyroll-takeout"))
I get basically the same error here:
File "/home/xbmc/.xbmc/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_video.py", line 22, in __init__
self.base_cache_path = os.path.join(xbmc.translatePath("special://masterprofile/"), "addon_data", os.path.basename(os.getcwd()))
Same change (minor edit) and it's working. Not sure what the system is returning for getcwd(), but the addon_data and addon_data/cache folders were there under my user data folder.
Can you please provide some additional information?
What build are you running?
What OS are you on?
Please post a pastebin of your xbmc log file showing the error if possible.
Could you add an option for default subtitle language? Just watched Oreimo S2E1 today, which, for some reason, has the subtitles as Portuguese by default. I can switch the subtitle language on crunchyroll.com, but not using this plugin.
suchipi, where are you located?
When I playback that episode I get English by default.
You should be getting whatever subtitles are default to you.
But as an apology I give you this YouTube video.
もってけセーラー服
* yoshiofthewire is tired
Didn't expect that
can you not fast forward with this addon? Whenever I do, it screws up the subtitles and gets more and more out of sync the more I fast forward.
The subtitles are at best temperamental.
Pausing almost always breaks subtitles and fast forward and rewind is not much better.
Skipping has given me better luck.
The alternative streaming method has baked in subs, so it won't de-sync but, it is only 360p
Unfortunately, when I try to watch anything it starts and then crashes XBMC. Using Frodo on a MacBook Air.
Please paste bin a log file, but if it crashes on viewing a video try the alternative streaming method.
If that works then it is the rtmp streamer on your install.
It was when I was watching Attack on Titan. I tried to do it again last night, but unfortunately, the video had been pulled from my geographical region. I tried another series, Space Brothers but the subtitles were out of sync by about 10-15 seconds. I've got the video set to 360p (SD).
Hi yoshiofthewire,
I'm located in the US. There might be a setting in my crunchyroll account for default language; I'll look for that. Thanks!
Edit: Thanks for the music mix, by the way xD
Edit2: Ah, in my crunchyroll settings I had set default language to JPN, thinking this was the audio language, when it was actually the softsub language. It appears to be working now. Thanks! Sorry for wasting your time ><
