Full Version: Background extra fanart displays fanart of deleted movies
Hi there,
I searched the forum (I really did!), but apparently none have the problem I have.
I have set my background of videos (movies and TV shows) in the main menu (home window) to extra fanart. So every 10 seconds the background changes. I LOVE this feature, adore it (we even play "guess the movie" with it).
BUT:
When you load a movie to the library... don't like... delete it again... clear the library...
It is still shown in the extra fanart backgrounds!!!
How can I get XBMC or the Aeon Nox-skin delete the extra fanart of deleted movies/ TV Shows?
After cleaning the library it should disappear.
As it doesn't you could use a trick (I do so) : use artwork organiser to save your fanart (movies, tvshows etc...) and choose the folder created as "multi-images" background. Then you save your fanart only time to time when you've added some movies/tv shows that you really like.
Sorry for the late response, been busy with an other thread that buggers me more :-)
At the moment I'm switching a lot between different builds and I think something went wrong somewhere.
For the moment it seems the problem has solved itself...
Should I encounter the problem again, I'll test that trick of yours!
