Full Version: block imdb scrapper from scanning some subdirectories
hi
i have a few folders that uses the IMDB scrapper.
it is set on the highest folder so it will populate to the sub directories.
in some of the sub directories i have some files that are not movies but clips. i went inside and removed the scrapper and also checked the block directory from scanning.
but they still show up.
after a scan i see that the setting for the scrapper is back (probably inherited it from above)
how can i really block it and keep it blocked?
thanks
tick the exclude from scan.
