(2019-03-24, 13:05)nonob Wrote: [ -> ]1- Could this function be added to estuary (just the average rate and sum of users from multiple sources) ?
Yes, it could be coded into the skin. Unfortunately it won't be. But you are free to ask in the Estuary forum.
(2019-03-24, 13:05)nonob Wrote: [ -> ]2- Which skins support several ratings ? (the most popular)
Aeon MQ7-
https://forum.kodi.tv/showthread.php?tid...pid2804280
AeonNox:Silvo-
https://forum.kodi.tv/showthread.php?tid...pid2813246
fTV-
(2019-03-24, 13:05)nonob Wrote: [ -> ]3- Is there any other solutions (apart of UMS and specific skin) to display multisource ratings (with Estuary if possible) ? I tried "extended info script" but it just display rating from TMDB...
No. Estuary has been designed to display a single rating which is the one that is set as default.
(2019-03-24, 13:05)nonob Wrote: [ -> ]It seems that when a movie doens't exist on Rotten i don't have rating displayed at all ? : it could be useful to fallback on another source when nothing is found on the first (i just had the problem with a french movie with the title not found on rotten i think; and as result i have no rating at all).
It should fall back to the rating that you do have. It all depends on how you are scraping the ratings.
This is how they are entered in NFO Files
xml:
<ratings>
<rating name="imdb" max="10" default="true">
<value>6.100000</value>
<votes>62204</votes>
</rating>
<rating name="metacritic" max="10">
<value>3.700000</value>
<votes>25</votes>
</rating>
<rating name="themoviedb" max="10">
<value>6.200000</value>
<votes>617</votes>
</rating>
<rating name="tomatometerallcritics" max="10">
<value>1.7</value>
<votes>247</votes>
</rating>
<rating name="tomatometerallaudience" max="10">
<value>4.0</value>
<votes>480,933</votes>
</rating>
</ratings>
Thanks a lot for all your reply
Have a nice day.
Hi there, I have a problem with kodi 18.1 and Universal Movie Scraper.
If i scan my movie library on kodi 18.1 and Universal movie scraper, the system can't find the last movie i've added (Spider-man: Into the spider Verse). If i run kodi 17.6 and universal movie scraper configured exactly the same way the system recognize the movie and download all the stuff connected to it.
I already have tried deleting the movie, cleaned the library, added again the movie and then scanned again --> No way
Can someone point me a possible alternative test to perform please?
Im using TinyMediaManager to set up my movie files as well as movie sets. Im using the Artic Zeyphr 2 skin on Leia and trying to figure out why the movie set posters and backgrounds I have set in TMM are not showing up when the files are added to Kodi and scraped?? I used Artwork Beef in the past and put all the movie set art in a separate folder. Does Universal Movie Scraper work the same way?? Or should it automatically see the files in the individual movie folder (for example: movieset-poster.jpg)
(2019-03-30, 01:34)Karellen Wrote: [ -> ]@Benna
Please provide the required information as detailed here... https://forum.kodi.tv/showthread.php?tid=336969
Thanks Karellen, reading the thread you suggested i've fixed the problem.
In my case i had to disable the video tags option, but i'll search informatio on the web about this feature because i think that it's a usefull feature to be kept active.
So, I'm having problem with this scraper.
I changed one configuration of it (add OMDb api key) and delete and add again one of the movies just to test if it work. The movie has not been added.
I took a look and noticed that some movies are not bein added to library. I can see a lot of
WARNING: No information found for item in logs.
I think a don't have problem with filenames of folders names, since this movies was added before.
Can someone help me with this?
LOG:
https://paste.kodi.tv/ojuyahibaz.kodi
edjalmo - we offer no support here for devices containing
banned addons (wiki) that violate our
piracy policy (wiki). That is all listed in the
forum rules (wiki) that you accepted and agreed to when you signed up here. Please go and actually read them before going any further. If you want help here then your device needs to be cleaned up and those addons and repos removed.
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2019-05-18, 23:22)DarrenHill Wrote: [ -> ]@edjalmo - we offer no support here for devices containing banned addons (wiki) that violate our piracy policy (wiki). That is all listed in the forum rules (wiki) that you accepted and agreed to when you signed up here. Please go and actually read them before going any further. If you want help here then your device needs to be cleaned up and those addons and repos removed.
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
I forgot that! I really sorry for that! This is will not happend again!
But I found my problem.
My problem was that the
Use video tags was enabled.
I disabled, updated library and the movies was added again
If someone has a similar problem you just need go to
Settings > Media > (enable advanced mode) > Videos > Use video tags
I'm hoping to rescan my library using this.
Is there any way possible to rescan and maintain the watched flag and any custom tags?
Date added seems to come in as expected.
Karellen
Thanks. I have the context tag add-on installed prior and found the Watchedlist add-on earlier. WL seems to do the trick.
Maybe it has already been suggested to have this addon have the option to force rescan without removing tags and the watched flag? (seeeing as it already doesn't affect the date added).
Hi!
There's a way I can get all rotten tomatoes ratings (critics and audiences)?
Because here I'm only get critics, even when I select audience in settings.
(2019-06-14, 15:33)edjalmo Wrote: [ -> ]Hi!
[url=javascript:void(0)][/url]
Reiterating
I get audience score in a movie called Central Station (1998), but others like The Fellowship of the Ring, Iron Man, Fast Five... I don't get.
