Hi guys
I miss two little step to make my system, built on ubuntu 11.10 minimal, perfect.
One, I describe here is the impossibility to set a splash screen.
I launch xbmc with the xbmc-live package script and I use uxlaunch (with uxlaunch selected when requested by the installer). The fact is that if I try to enable a splash screen with this istructions:
http://wiki.xbmc.org/index.php?title=HOW...oot_Splash
the result is that I don't get any splash screen and the boot process hangs because in dmesg the nVidia drivers claim that the device is already taken.
Do we have updated way to enable spalsh screen?
It's worth to mention that I run nVidia ION2 system and it seems there is a general problem with framebuffer
Bye
did you add "NoLogo" under "Device" section in xorg.conf to stop the nvidia
splash from showing up.
Quote:[ 10.328043] uvesafb: Getting VBE info block failed (eax=0x4f00, err=1)
[ 10.328162] uvesafb: vbe_init() failed with -22
[ 10.328277] uvesafb: probe of uvesafb.0 failed with error -22
[ 13.839573] r8712u: CustomerID = 0x0000
[ 13.839584] r8712u: MAC Address from efuse = e0:b9:a5:22:f4:ae
[ 13.841658] usbcore: registered new interface driver r8712u
[ 13.955338] [drm] nouveau 0000:04:00.0: allocated 1920x1080 fb: 0x40000000, bo ffff880036c2fc00
[ 13.955579] fbcon: nouveaufb (fb1) is primary device
[ 13.955589] fbcon: Remapping primary device, fb1, to tty 1-63
[ 14.222959] [drm] nouveau 0000:04:00.0: unknown PDISPLAY_INTR_1: 0x00000100
[ 14.435188] fb1: nouveaufb frame buffer device
[ 14.435193] drm: registered panic notifier
[ 14.435209] [drm] Initialized nouveau 0.0.16 20090420 for 0000:04:00.0 on minor 0
[ 14.435356] HDA Intel 0000:04:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 14.435486] HDA Intel 0000:04:00.1: setting latency timer to 64
[ 14.455512] uvesafb: mode switch failed (eax=0x14f, err=0)
[ 14.455523] detected fb_set_par error, error code: -22
[ 14.458972] nvidia: module license 'NVIDIA' taints kernel.
[ 14.458981] Disabling lock debugging due to kernel taint
[ 14.459386] uvesafb: mode switch failed (eax=0x14f, err=0)
[ 14.459394] detected fb_set_par error, error code: -22
[ 14.462690] uvesafb: mode switch failed (eax=0x14f, err=0)
[ 14.462699] detected fb_set_par error, error code: -22
[ 15.030620] EXT3-fs (sda5): error: can't find ext3 filesystem on dev sda5.
[ 15.061922] r8169 0000:02:00.0: eth0: link up
[ 15.062759] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.244037] HDMI status: Pin=5 Presence_Detect=0 ELD_Valid=0
[ 15.276035] HDMI status: Pin=5 Presence_Detect=0 ELD_Valid=0
[ 15.308034] HDMI status: Pin=5 Presence_Detect=0 ELD_Valid=0
[ 15.340035] HDMI status: Pin=5 Presence_Detect=0 ELD_Valid=0
[ 15.356244] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1c.0/0000:04:00.1/sound/card1/input3
[ 15.356620] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1c.0/0000:04:00.1/sound/card1/input4
[ 15.356895] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1c.0/0000:04:00.1/sound/card1/input5
[ 15.357241] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1c.0/0000:04:00.1/sound/card1/input6
[ 15.381555] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[ 15.381568] NVRM: This can occur when a driver such as nouveau, rivafb,
[ 15.381572] NVRM: nvidiafb, or rivatv was loaded and obtained ownership of
[ 15.381575] NVRM: the NVIDIA device(s).
[ 15.381584] NVRM: Try unloading the conflicting kernel module (and/or
[ 15.381587] NVRM: reconfigure your kernel without the conflicting
[ 15.381591] NVRM: driver(s)), then try loading the NVIDIA kernel module
[ 15.381594] NVRM: again.
[ 15.381600] NVRM: No NVIDIA graphics adapter probed!
[ 15.420387] EXT2-fs (sda5): error: can't find an ext2 filesystem on dev sda5.
[ 15.444481] EXT4-fs (sda5): VFS: Can't find ext4 filesystem
[ 15.700863] init: ssh main process (516) terminated with status 255
[ 15.744565] init: failsafe main process (591) killed by TERM signal
[ 15.801113] type=1400 audit(1335337837.230:5): apparmor="STATUS" operation="profile_load" name="/usr/sbin/tcpdump" pid=934 comm="apparmor_parser"
[ 15.801557] type=1400 audit(1335337837.230:6): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=933 comm="apparmor_parser"
[ 15.802720] type=1400 audit(1335337837.230:7): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=933 comm="apparmor_parser"
[ 15.803556] type=1400 audit(1335337837.230:8): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=933 comm="apparmor_parser"
[ 15.807668] type=1400 audit(1335337837.234:9): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm-guest-session-wrapper" pid=932 comm="apparmor_parser"
[ 16.048605] init: lightdm main process (1006) killed by TERM signal
[ 16.750686] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[ 16.750695] NVRM: This can occur when a driver such as nouveau, rivafb,
[ 16.750698] NVRM: nvidiafb, or rivatv was loaded and obtained ownership of
[ 16.750701] NVRM: the NVIDIA device(s).
[ 16.750707] NVRM: Try unloading the conflicting kernel module (and/or
[ 16.750710] NVRM: reconfigure your kernel without the conflicting
[ 16.750712] NVRM: driver(s)), then try loading the NVIDIA kernel module
[ 16.750715] NVRM: again.
[ 16.750719] NVRM: No NVIDIA graphics adapter probed!
[ 17.139030] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,commit=0
[ 25.440010] eth0: no IPv6 routers present
[ 25.853914] uxlaunch (733): /proc/1156/oom_adj is deprecated, please use /proc/1156/oom_score_adj instead.
[ 27.859675] init: uxlaunch main process (726) killed by KILL signal
mmmm it looks like there are two issue. uvesafb seems to be unable to probe the framebuffer and then nVidia driver goes crazy
