Full Version: Wakw On Lan
Hello to you all.
ive been serching for ages and i just cant quite get my head round a key map to launch advanced Wol
i have tried
<keymap>
<global>
<keyboard>
<h>Runscript(private/var/mobile/Library/Preferences/XBMC/addons/script.advanced.wol/default.py)</h>
</keyboard>
</global>
<Home>
</keymap>
and
<keymap>
<global>
<keyboard>
<h> Runscript(script.advanced.wol)</h>
</keyboard>
</global>
<Home>
</keymap>
i put it in a text file in keymaps folder un keymaps.xml but just cant get it to work
i will be realy grateful for any help
bump
ok i got round the problem by using constellation app for the iphone http://fss.cc/constellation/ as this will launch addons as long as you have alowed port forwarding on the jsonrpc port 9090 to the apple tv.
1 http://www.no-ip.com/ (put the setings in the btrouter)
2 http://fss.cc/constellation/ (port forward the 3 ports to apple tv)
3 turn on remote in xbmc
