2012-04-26, 08:16
I have a fresh install of XBMCbuntu eden final on my Shuttle XS35 but I am unable to make it suspend to ram. When suspend is selected the screen flickers but then nothing else happens, the XBMC continues to work without a problem. Initially I thought this was due a problem with the remote control but it won't suspend from the menu either. Shutdown and reboot work fine.
Here is the relevant section of the log:
The entire log can be found here:
http://pastebin.com/x4jLvnfF
Any help would be greatly appreciated.
07:10:57 T:7096336 DEBUG: SDLKeyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
07:10:57 T:7096336 DEBUG: OnKey: right (f083) pressed, action is Right
07:10:58 T:7096336 DEBUG: SDLKeyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
07:10:58 T:7096336 DEBUG: OnKey: right (f083) pressed, action is Right
07:10:59 T:7096336 DEBUG: SDLKeyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
07:10:59 T:7096336 DEBUG: OnKey: right (f083) pressed, action is Right
07:11:00 T:7096336 DEBUG: SDLKeyboard: scancode: 71, sym: 0114, unicode: 0000, modifier: 0
07:11:00 T:7096336 DEBUG: OnKey: left (f082) pressed, action is Left
07:11:01 T:7096336 DEBUG: SDLKeyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
07:11:01 T:7096336 DEBUG: OnKey: down (f081) pressed, action is Down
07:11:01 T:7096336 DEBUG: ExecuteXBMCAction : Translating Control.SetFocus(301,0)
07:11:01 T:7096336 DEBUG: ExecuteXBMCAction : To Control.SetFocus(301,0)
07:11:02 T:7096336 DEBUG: SDLKeyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
07:11:02 T:7096336 DEBUG: OnKey: down (f081) pressed, action is Down
07:11:03 T:7096336 DEBUG: SDLKeyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
07:11:03 T:7096336 DEBUG: OnKey: down (f081) pressed, action is Down
07:11:03 T:7096336 DEBUG: SDLKeyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 0
07:11:03 T:7096336 DEBUG: OnKey: return (f00d) pressed, action is Select
07:11:03 T:7096336 DEBUG: ExecuteXBMCAction : Translating Suspend()
07:11:03 T:7096336 DEBUG: ExecuteXBMCAction : To Suspend()
07:11:03 T:7096336 DEBUG: DBus: Creating message to org.freedesktop.UPower on /org/freedesktop/UPower with interface org.freedesktop.UPower and method AboutToSleep
07:11:03 T:7096336 DEBUG: DBus: Creating message to org.freedesktop.UPower on /org/freedesktop/UPower with interface org.freedesktop.UPower and method Suspend
07:11:04 T:7096336 DEBUG: CAnnouncementManager - Announcement: OnSleep from xbmc
07:11:04 T:7096336 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnSleep
07:11:04 T:7096336 NOTICE: OnSleep: Running sleep jobs
07:11:04 T:7096336 NOTICE: OnSleep: Stopping lirc
07:11:04 T:7096336 INFO: LIRC setUsed: disabled
07:11:04 T:7096336 DEBUG: UPower: Recieved an unknown signal NotifySleep
07:11:06 T:7096336 NOTICE: OnWake: Running resume jobs
07:11:06 T:7096336 ERROR: GLX: Same window as before, refreshing context
07:11:06 T:7096336 INFO: GL: Maximum texture width: 8192
07:11:06 T:7096336 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
07:11:06 T:7096336 DEBUG: OnLostDevice - notify display change event
07:11:06 T:7096336 NOTICE: OnWake: Restarting lirc
07:11:06 T:7096336 INFO: LIRC Initialize: using: /dev/lircd
07:11:06 T:7096336 INFO: LIRC Initialize: connect failed: No such file or directory
07:11:06 T:7096336 DEBUG: Failed to connect to LIRC. Retry in 10s.
07:11:06 T:7096336 NOTICE: OnWake: Restarting lcd
07:11:06 T:7096336 DEBUG: CAnnouncementManager - Announcement: OnWake from xbmc
07:11:06 T:7096336 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnWake
07:11:06 T:2964290416 DEBUG: Thread Jobworker start, auto delete: 1
07:11:06 T:2964290416 INFO: WEATHER: Downloading weather
07:11:06 T:2964290416 INFO: initializing python engine.
07:11:06 T:2964290416 DEBUG: new python thread created. id=5
07:11:06 T:2997861232 DEBUG: Thread XBPyThread start, auto delete: 0
07:11:06 T:2997861232 DEBUG: Python thread: start processing
07:11:06 T:2997861232 NOTICE: -->Python Interpreter Initialized<--
07:11:06 T:2997861232 DEBUG: Process - The source file to load is /usr/share/xbmc/addons/weather.wunderground/default.py
07:11:06 T:2997861232 DEBUG: Process - Setting the Python path to /usr/share/xbmc/addons/weather.wunderground:/usr/share/xbmc/addons/script.module.simplejson/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/xbmc/.xbmc/addons/script.common.plugin.cache/lib:/home/xbmc/.xbmc/addons/script.module.simple.downloader/lib:/home/xbmc/.xbmc/addons/script.module.parsedom/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:
07:11:06 T:2997861232 DEBUG: Process - Entering source directory /usr/share/xbmc/addons/weather.wunderground
07:11:06 T:2997861232 DEBUG: Instantiating addon using automatically obtained id of "weather.wunderground" dependent on version 2.0 of the xbmc.python api
07:11:07 T:2997861232 INFO: Scriptresult: Success
07:11:07 T:2997861232 INFO: Python script stopped
07:11:07 T:2997861232 DEBUG: Thread XBPyThread 2997861232 terminating
07:11:07 T:7096336 DEBUG: waiting for python thread 5 to stop
07:11:07 T:7096336 DEBUG: python thread 5 destructed
07:11:07 T:7096336 DEBUG: UPower: Recieved an unknown signal NotifyResume
07:11:09 T:7096336 ERROR: CheckDisplayEvents - no display event after 3 seconds
07:11:09 T:7096336 DEBUG: CheckDisplayEvents - notify display reset event
07:11:17 T:7096336 INFO: LIRC Initialize: using: /dev/lircd
07:11:17 T:7096336 DEBUG: Failed to connect to LIRC. Retry in 20s.
