So i wanted to edit a skin and find the myvidenav.xml
But there is no xbmc folder in application support
i also checked under application/xbmc/show content but nothing, what gives?
i really want to edit a skin im using
using 10.7.3 lion
im also using latest nightly eden
the powers that be at apple decided that users should not see that folder but it's present. google knows how to show it.
not /applocation support/xbmc , but /Users/<your username>/Application Support/XBMC
The folder is hidden.
To unhide
chflags nohidden ~/Library/
And it will be in /Users/<username>/Library/Application support/XBMC
You can also click on the Go menu in Finder and push the option key. Library then becomes a clickable item.
(2012-04-27, 07:14)Dori Wrote: [ -> ]The folder is hidden.
To unhide
Had the same problem finding it. This worked like a charm, thank you.
