2005-06-29, 22:39
2005-07-01, 10:33
now on xbmcscripts.com
2005-07-01, 12:52
hi dave - not sure what i did, but the script crashes my xbox.. ive exctracted the script and pannel.png to its own folder... i get the slide out lists (without background) - i select something, but then nothing - it gets stuck on (running) and i cant seem to exit.
i guess i`ll have to go through the logs to be more help though !
2005-07-02, 02:45
hi dave,
also having the problem with the script... i get the cool floating window where you can choose your show - but the respective episode lists do not come up. usually i can back out to choose another show - with no episodes appearing - sometimes it just hangs.
very intrigued by this... would love to see it working.
coreyinoz
p.s. what about the sister site pr0nfridge.com? :evil:
coreyinoz
2005-07-02, 02:55
dave,
i just tried this script... amazing!!!
it is working perfectly!
one small (i hope) request... can you make the overlay background darker. with the white text it is difficult to see since the background is almost completely transparent.
or if you just want to point out the line to me and what to adjust i can do it.
thanks for a fantastic script!
2005-07-02, 14:30
hi i found the problem n will send a update to xbmcscripts.com sunday evening (gmt) those who i emailed should work fine. ill make the background darker or change the text. ill have a look either way.
2005-07-02, 14:43
nice script,
panel2.png included with pmiii and in cvs is darker and i think most newer skins would have this so you wouldn't have to include it.
it does have a divider at the bottom, but doesn't interfere with the list.
edit: if you add xbmc.executebuiltin('xbmc.activatewindow(2005)') after you play the movie, it sets it to fullscreen.
2005-07-02, 17:06
@jj5768 is the directory you put it in name "crafty tv"? don't forget the space.
2005-07-02, 18:25
2005-07-03, 10:38
ican not get it ti work what iam i doing wronge all the rest work :veryangry:
2005-07-03, 14:23
is crafttv down now or is it just have issues now?
2005-07-03, 15:34
Quote:is crafttv down now or is it just have issues now?
like i said i found a bug n will send a update sunday eve. i will also add full screen. thanks 4 the info
2005-07-03, 21:48
well, i can't even get to http://www.craftytv.com on my computer
2005-07-03, 23:45
nah nor me, thats a recent thing was working yesturday, hoping its nothing serious, if its bak up tommorow ill upload my script den
2005-07-04, 00:15
seems to be their dns provider stopped handling their domain... weird... guess they forgot to pay the bill?
