2005-06-19, 20:26
2005-06-21, 17:40
thx i needed that :kickass: good idea :thumbsup:
2005-06-21, 18:18
hey man, i found a little bug with your script tho, when your playing music, and the poker timer u can't go back to the menu, or if u do , u can't get back to the poker timer. and also would u be able to make it a differernt button then x. i think that may be the reason y u can't go back into the menu etheir, cuz the music visualisations r also x. peace out :kickass:
2005-06-21, 19:03
if you mean you can't go back to the script window, it's because this script doen't run in the background, it just hides the pad. not sure how to make it run in the background and be able to pause the timer.
you can still control your music or video playlist. with the control pad press start to bring up the player controls.
if you're having problems pausing the timer. there's a sleep() statement in there that may need to be increased. are you able to pause the timer? if not the button isn't getting focus and increasing the sleep() would help.
the x button could be changed, but it works fine here.
i'm not sure what you meant.
2005-06-22, 01:07
ya tru , i forgot about the play list lol, i never use it lol,
