Full Version: XBMCbuntu 'power off' and 'reboot' drop back to LXDE Login Screen
Just deployed XBMCbuntu and everything has been great so far. However, one weird quick I have run into is that when inside XBMC I go to Power Options, and choose Power off or Reboot - it just drops me back to the login screen. What gives?
At the moment I'm doing my shutdown/reboots via SSH.
Everything is default (skin, etc).
Thanks in advance
Some more information:
Reboot now works as expected.
"Power Off" still takes me back to the Login Screen.
"shutdown -h now" via SSH works fine.
Any ideas?
I had the same problem with a Asrock MB. When I disabled the USB3 ports it started to work properly, though I can't say for sure that is what fixed it.
