Full Version: XBMC Nightly hangs when updating libary
Hello,
I'm using XBMC a few weeks now and I like it a lot.
I wanted to try the newest ones so I installed various nightly builds earlier this week but yesterday they started
to hang after a few seconds after starting the programm and it started to scan for new libary entries.
I installed Eden again and it worked, but finding the libary all over again so I had to remove the duplicates.
Do I have to completely uninstall Eden before installing the nightly builds to get the to work properly?
thnx.
No you should only backup you data to be sure.
Remember that nightlies are alpha versions and are only meant for testing and if you know what you are doing.
If you want stable stick with the official 11.0 release
and i have the same happening here. will probably be fixed in newer nightlies
Oke, Thank you Smile
I'm aware of the downside of using nightlies. I just wanted to share my experiences.
Didn't know if this was a problem due to my setup or a bug in XBMC.
Is this issue adressed meanwhile?
