Full Version: Best way to manually manage metadata?
Hey guys, Loving XBMC Eden. Im having a couple of scraper issues. and im not complaining about that. I know XBMC isnt perfect (close!)
Im looking at using a meta data manager like EMBER.
However.
How can i get it to integrate with XBMC properly?
XBMC has already downloaded everything in my library. I forget exactly how to clean it (deleting a library file somewhere i think, and cleaning the library?)
How can i get XBMC to use everything i download in EMBER? Everytime i add the sources to XBMC it scans by itself and often replaces it, or just doesnt show up?
And what is best to use for XBMC png/jpg etc? I selected them all in ember.
Thanks guys
I use Ember as well, and I use .jpg only... for no great reason. The fact is you DO NOT need to have them all selected - just choose one.
The easiest way to update XBMC and use your Ember created files is to remove the source completely. Then add the source back, when it asks if it shoud refresh data, select no. XBMC will simply use all the data that EMBER has created.
Hope that helps.
