Sho just finalized
a feature I requested a few weeks ago and said it is available in the latest commit. I removed my old version of XBMC and switched over to the git package, so that's not the problem.
Sho Wrote:Changed 15 hours ago by sho
status changed from new to closed
resolution set to Fixed
milestone changed from Future / Pending to 12.0
With commit 691095a6134ff6df7ce3804eba889037ec155f9c you will simply be allowed to remove the node and replace it with whatever you want.
Does this only apply to the file list? Library? Sub-menu under TV on the home screen? No matter what I do I can't find an option to remove the
Recently Added node.
It applies to the library. See system/library in the XBMC folder. Copy that to userdata/Database (i.e. copy the video and/or video_flat folders).
Then edit as you please.
Ah, it requires manual editing huh? No wonder I couldn't find it! Thanks.
So, yea, it turns out I don't have the library file/folder that you're speaking of:
Quote: [bran@ra ~]$ ls /usr/share/xbmc/system
keymaps players python shaders asound.conf colors.xml IRSSmap.xml Lircmap.xml peripherals.xml playercorefactory.xml X10-Lola-IRSSmap.xml
[bran@ra ~]$ ls ~/.xbmc/system/
[bran@ra ~]$ locate xbmc|grep library
/home/bran/.xbmc/addons/service.libraryautoupdate
/home/bran/.xbmc/addons/packages/service.libraryautoupdate-0.6.0.zip
/home/bran/.xbmc/addons/packages/service.libraryautoupdate-0.6.1.zip
/home/bran/.xbmc/addons/service.libraryautoupdate/LICENSE.txt
/home/bran/.xbmc/addons/service.libraryautoupdate/README.txt
/home/bran/.xbmc/addons/service.libraryautoupdate/addon.xml
/home/bran/.xbmc/addons/service.libraryautoupdate/changelog.txt
/home/bran/.xbmc/addons/service.libraryautoupdate/default.py
/home/bran/.xbmc/addons/service.libraryautoupdate/disclaimer.py
/home/bran/.xbmc/addons/service.libraryautoupdate/icon.png
/home/bran/.xbmc/addons/service.libraryautoupdate/manual.py
/home/bran/.xbmc/addons/service.libraryautoupdate/resources
/home/bran/.xbmc/addons/service.libraryautoupdate/service.py
/home/bran/.xbmc/addons/service.libraryautoupdate/service.pyc
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/__init__.py
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/__init__.pyc
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/images
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/language
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/lib
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/settings.xml
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/images/clock.png
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/language/English
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/language/English/strings.xml
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/lib/__init__.py
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/lib/__init__.pyc
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/lib/croniter.py
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/lib/croniter.pyc
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/lib/relativedelta.py
/home/bran/.xbmc/addons/service.libraryautoupdate/resources/lib/relativedelta.pyc
/home/bran/.xbmc/userdata/addon_data/service.libraryautoupdate
/home/bran/.xbmc/userdata/addon_data/service.libraryautoupdate/last_run.txt
/home/bran/.xbmc/userdata/addon_data/service.libraryautoupdate/settings.xml
/usr/lib/xbmc/system/players/paplayer/stsoundlibrary-x86_64-linux.so
Thanks for the link, but it turns out I don't have the video or video_flat folders either, so where am I supposed to start since I don't have anything to edit?
you start by obtaining a new enough build.
Found the culprit, it was set in the PKGBUILD (I'm using Chakra Linux) to pull down commit: c317d94f16be7cafbc34b0b24f8d5336547cc6ca
