Full Version: A black screen & an error on XP
It happens just after clicking the program, bothing appears before - just a black screen with the well known XP error messege...
No log file was created! what can I do?
XBMC 11.0 EDEN
AMD Radeon 9600
tell me what detail you need in order to help me Smile
I don't know if it has any connection to this but the same version worked on this computer in the last XP version which was on it,
the XP version Im using now is a new one, after I've formatted it.
UP.
Any idea??
I've installed win7 now and it does the same problem
I suspect a graphic limitation, I had a similar issue and the Dharma build worked. Interesting that Eden did work at one point.
