Full Version: Using XBMC on Squeeze.
Dear forum readers,
i'm new here, i'm 30 years old and i'm a strong computer enthusiast.
i have a box on my network that i primarily use for my file storage and git repos.
i decided that this box would be of a good use as a media center also, since when i'm watching a movie, i'm not working...
The box is a Debian Squeeze, with a 64ibit 3.2 kernel from the backports repos. i recently also added the multimedia repos, so i can try XBMC (This box didn't have an X window system, it was streaming my movies to my laptop via Plex Media Server, and i'm most of the case using SSH to access the box when i need to start a virtual machine or to change some of it's configuration).
Right now, what i wish to achieve would be to be able to have XBMC running all the time on this box, so i have installed xorg along with XBMC.
i have managed to find a script to be able to start / stop XBMC via rc.d on another website. However, when i try to start XBMC, it doesn't show and returns to my console with the log attached at the end of the topic.
i'm wondering... Since i'm able to start xinit (i can see xterm and use it, so i guess my xorg is configured), and since i am using a i5 processor, could it be related to the fact that this processor doesn't have a powerfull-enough GPU (Or maybe that this processor might not be supported at all for OpenGL)?
If you have any idea or if you know what i am doing wrong (And since i'm very new to the whole XBMC system, that has to be something i'm doing wrong), could you please explain me what direction i shall head to to solve this issue?
Thanks a lot!
Pierre.
[edit]Oh and the XOrg output might be relevant, i don't know... It doesn't show any error, just a few warnings, but i'm attaching it at the end.[/edit]
18:56:47 T:140535855814688 M:7877419008  NOTICE: -----------------------------------------------------------------------
18:56:47 T:140535855814688 M:7877419008  NOTICE: Starting XBMC, Platform: Linux (Debian GNU/Linux 6.0.4 (squeeze), 3.2.0-0.bpo.1-amd64 x86_64). Built on Nov 20 2011 (SVN:Unknown)
18:56:47 T:140535855814688 M:7877419008  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
18:56:47 T:140535855814688 M:7877419008  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
18:56:47 T:140535855814688 M:7877419008  NOTICE: special://masterprofile/ is mapped to: /home/users/mainuser/.xbmc/userdata
18:56:47 T:140535855814688 M:7877419008  NOTICE: special://home/ is mapped to: /home/users/mainuser/.xbmc
18:56:47 T:140535855814688 M:7877419008  NOTICE: special://temp/ is mapped to: /home/users/mainuser/.xbmc/temp
18:56:47 T:140535855814688 M:7877419008  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
18:56:47 T:140535855814688 M:7877419008  NOTICE: Log File is located: /home/users/mainuser/.xbmc/temp/xbmc.log
18:56:48 T:140535855814688 M:7877165056  NOTICE: Setup SDL
18:56:48 T:140535855814688 M:7877296128  NOTICE: load settings...
18:56:48 T:140535855814688 M:7877296128  NOTICE: special://profile/ is mapped to: special://masterprofile/
18:56:48 T:140535855814688 M:7877296128  NOTICE: loading special://masterprofile/guisettings.xml
18:56:48 T:140535855814688 M:7877296128  NOTICE: Getting hardware information now...
18:56:48 T:140535855814688 M:7877296128  NOTICE: Checking resolution 12
18:56:48 T:140535855814688 M:7877296128  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:56:48 T:140535855814688 M:7877296128  NOTICE: Loaded playercorefactory configuration
18:56:48 T:140535855814688 M:7877296128  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:56:48 T:140535855814688 M:7877296128  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:56:48 T:140535855814688 M:7877296128  NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
18:56:48 T:140535855814688 M:7877296128  NOTICE: Default DVD Player: dvdplayer
18:56:48 T:140535855814688 M:7877296128  NOTICE: Default Video Player: dvdplayer
18:56:48 T:140535855814688 M:7877296128  NOTICE: Default Audio Player: paplayer
18:56:48 T:140535855814688 M:7877296128  NOTICE: Loading media sources from special://masterprofile/sources.xml
18:56:48 T:140535855814688 M:7873699840  NOTICE: Using visual 0x22
18:56:48 T:140535855814688 M:7870263296   ERROR: InitRenderSystem() glewInit returned 1: Missing GL version
18:56:48 T:140535855814688 M:7870263296   FATAL: CApplication::Create: Unable to init rendering system
X.Org X Server 1.10.4
Release Date: 2011-08-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.0.0-1-amd64 x86_64 Debian
Current Operating System: Linux Theatre 3.2.0-0.bpo.1-amd64 #1 SMP Sat Feb 11 08:41:32 UTC 2012 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-0.bpo.1-amd64 root=UUID=283a7c6b-3c02-4891-9a66-8820a8f6b149 ro quiet
Build Date: 28 August 2011  09:39:43PM
xorg-server 2:1.10.4-1~bpo60+1 (Cyril Brulebois <[email protected]>)
Current version of pixman: 0.16.4
    Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu May  3 01:38:57 2012
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Running DIL (0.9.27) Version
DtsDeviceOpen: DtsGetDevID Failed
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Multiple interpretations of "NoSymbol+AnyOf(all)"
>                   Using last definition for duplicate fields
[A LOT OF NoSymbol+AnyOf(All) WARNINGS...]
> Warning:          Multiple interpretations of "NoSymbol+AnyOfOrNone(all)"
[A LOT OF NoSymbol+AnyOfOrNone(all) WARNINGS...]
Errors from xkbcomp are not fatal to the X server
ERROR: Unable to create application. Exiting
waiting for X server to shut down
