HELLO good folks of XBMC
EDITED: I bought the below parts
Requirements I have: Good Blu-Ray, less than 33cm deep, discrete looks, 1080p 3D, ease of use and maintenance.
So this is what i chose:
Chassis: Lian Li PC-C50B
CPU: AMD A8-3850
CPUCooler: Scythe Big Shuriken II Rev. B
PSU: Seasonic X-400FL 400W
SSD: Crucial M4 128GB
HDD: Western Digital Caviar Green 2TB
Mobo: ASUS F1A75-I Deluxe
RAM: Corsair XMS3 DDR3 1600Mhz 2x2 GB CL9
ODD: Lite-On Blu-ray Writer iHBS212
OS: Windows Home Premium EN
Remote: Logitech Wireless Touch Keyboard K400
TOTAL: 10 744 +/- Swedish Crowns
I will take pictures and perhaps record the building of it.
Cheers
Systemic33
EDIT: Added picture for ur pleasure
I love the case..... get the BIG shuriken 2100 120MM ..... it just works!
You may just need one exhaust fan and that's it!
Lian LI makes very nice products....
infact I want to change my unraid server case to a lian li...
I was a bit worried if it was too wide, and too low for the RAM, and saw that this Samurai was pretty silent.
EDIT: Case has 130mm CPU cooler height, so its not such a tight fit
(2012-05-04, 01:45)Systemic33 Wrote: [ -> ]I was a bit worried if it was too wide, and too low for the RAM, and saw that this Samurai was pretty silent.
Mmmm that is a huge case..... it should fit....
oh your ram....get something that fits it.....
the crucial balisticx fits it..
Big shuriken should fit, so i changed to that
Since you have a bigger case and PSU, why not go for a more powerful APU-
AMD A8-3850.....it'll get the job done quicker.....
Looks nice, but also if you are going to spend that much why not 400 sek more and get the A8-3870? Not that the A6 will do the job just fine.
And 10744sek? if you are use prisjakt.se it adds op to about 8000 without Win7 from one internet shop (migh be cheeper if you go hunting)
I have made a list for you, give it a look before you make up your minde
One sweden/danish to another
http://www.prisjakt.nu/list.php?l=2143976&view=o
Edit: Just saw the "OBS: Not too concerned about saving money."... but still if you can save 1000++ on the same thing isn't that worth looking into?
(2012-05-04, 03:56)bluray Wrote: [ -> ]Since you have a bigger case and PSU, why not go for a more powerful APU- AMD A8-3850.....
Agreed, the A6-3500 is likely all you need, but if you don't care about an extra $50 or whatever, get a better CPU. "Just in case" ..
E.g., if you want to start editing movies, or doing more CPU intensive tasks 3/6 months down the line that you weren't thinking of now that is. Though I guess you could always just remove the 3500 and replace it at that time.
(2012-05-04, 09:09)XtuX Wrote: [ -> ]Looks nice, but also if you are going to spend that much why not 400 sek more and get the A8-3870? Not that the A6 will do the job just fine.
I have made a list for you, give it a look before you make up your minde One sweden/danish to another
Wow, i didn't know prisjakt.nu could do that ^^ cool
I can see how I could save a 1000 kr there, but since its my dad who buys, and im only there to be able to build it 12-13 th may, it has to be pretty simple to order and eventually RMA, would be really sad if everything except one thing came, So by keeping it to only Webhallen and Inet, (didn't specify that in the OP) it becomes simple, and i've bought there before so i know that they are reliable.
I might consider the Dustin, MISCO, Proshop combo though.
(2012-05-04, 13:33)Sdpbc Wrote: [ -> ] (2012-05-04, 03:56)bluray Wrote: [ -> ]Since you have a bigger case and PSU, why not go for a more powerful APU- AMD A8-3850.....
Ye, the A8-38xx is almost twice the price of a A6-3500, so I think by the time it could be relevant, some new thing would've come out anyway
(2012-05-04, 14:24)Systemic33 Wrote: [ -> ]Ye, the A8-38xx is almost twice the price of a A6-3500, so I think by the time it could be relevant, some new thing would've come out anyway
I wouldn't say $20 more twice the price.....yes, AMD is coming out with a new Trinity but it'll be completely new socket (FM2) though....
Cool cool.!
OBS. sometimes prisjakt.nu make a yellow on lagerstatus because there is a 1-4 day delevering instad of 1-2 days. I ordered all my parts from proshop.se and the mobo had a yellow status on prisjakt but still recived it all at the sametime 3 days later
(2012-05-04, 20:50)XtuX Wrote: [ -> ]Cool cool.!
Hmm, might be true.
BTW, I've now bought the items that is in the first post now
(2012-05-04, 21:56)Systemic33 Wrote: [ -> ] (2012-05-04, 20:50)XtuX Wrote: [ -> ]Cool cool.!
Hmm, might be true.
You'll have a powerful HTPC and you'll enjoy it...! Can you correct your title and first post? It should be A8-3850......
